Possible Purchase Vizio 42" VO420E Black Vertical Band
  • MisterD
    • Oct 2012
    • 668
    This is the best I can do for now, for those that think I'm wasting your time (SORRY!) but for those that can and want to reply, any Ideas on this one?
    Thanks In Advance
    Re: Possible Purchase Vizio 42" VO420E Black Vertical Band
    Bad panel! Don't touch it!
    Any TVs which are dead etc? Those are the easiest to repair. Start tracing where voltages disappear, or something...
    • MisterD
      • Oct 2012
      • 668
      Thanks Tom66! So basically any LCD with any width size vertical lines is most likely to be a bad panel, is that usually the case? does this apply to Plasmas as well?
        Yes. And yes.
        I also saw a Samsung 50 inch plasma on sale on Gumtree (free ad site like Craigslist.) It was a bad panel but from the photo I immediately knew that the guy had broken it accidentally while trying to repair another fault. Half the screen was black apart from a few white lines I'll call "fuzzies" -- these weren't solid, but intermittent. The only way that happens is if you disconnect the address connector and plug it in while the set is running. BANG! goes the panel drivers, and suddenly half the screen doesn't work.
        • MisterD
          • Oct 2012
          • 668
          I forgot to ask, Is it just black vertical lines or any color? Thanks!
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Any vertical lines
              Any vertical line. It means the driver IC for that area of the screen is fried. A single line is a fried output on the driver but the rest of the IC works. A black or white bar is a completely fried driver. And the drivers are bonded to the panel.
              edit: Pentium beat me to it.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Yeah but you gave a thorough description of why
                • MisterD
                  • Oct 2012
                  • 668
                  I recently repaired a 42" Vizio LCD/LED Edge by replacing the T-CON Board, it had been working great for 2 weeks but on Thanksgiving Day it had been on for probably 12 hours when two faint black vertical lines about 2" apart appeared in the very middle of the screen, I had it on a cable channel, tried several channels and it was the same on all of them. Turned TV Off for a few minutes then back on, the lines disappeared and have not returned yet.
                  (keeping my fingered crossed) with the tv being on several hours at a time.
                    May just be bad tab bonds if they are transient.
                    • MisterD
                      • Oct 2012
                      • 668
                      Where are the Tab Bonds Located?
                        https://www.youtube.com/watch?v=yqcqDQFqZHo&t=55s
                        • MisterD
                          • Oct 2012
                          • 668
                          Awesome Video, Thanks!
                          • johnpeg
                            • 22
                            I have a vizio that almost looks the same as the first pic. The difference is it is the whole left side. When I leave it on for about 30 -45 mins. it works great. Is there a shot that it is the tcon board? I was wondering this because of it working fine when it runs for a while. Any ideas will be very helpful. Thank You in advance
                            • howardc64
                              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                              by howardc64
                              Failure Symptom
                              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                              Where is the short?
                              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                              05-27-2025, 02:56 PM
                            • otaku_nut
                              Vizio E701i-A3 fixed but now has red vertical line
                              by otaku_nut
                              Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                              08-19-2025, 06:11 PM
                            • brad2157
                              Vizio E70-E3 Two white vertical lines
                              by brad2157
                              I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                              Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                              Replacement main board - Boots up fine, but starting...
                              12-13-2021, 05:11 PM
                            • viking509
                              vizio e65 e3 LED tv color vertical lines center tv only
                              by viking509
                              I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                              03-21-2023, 12:48 AM
