Sony Bravia KDL-52S4100 No picture or Sound
  • topfli8979
    • Oct 2012
    • 311
    Re: Sony Bravia KDL-52S4100 No picture or Sound
    Where did you find the firmware update? Sony has none available for this model on there site?
    • capkid
      • Oct 2010
      • 1339
      https://www.badcaps.net/forum/showpo...6&postcount=18
      LG Plasma Mal-Discharge Correction Service
      • topfli8979
        • Oct 2012
        • 311
        That is awesome!! Thank you. It actually worked. This forum is amazing with the help a guy receives!
        • figureditout
          • Jun 2015
          First and foremost, I'd like to thank you all very very much for having this online discussion. It's the only place that I could find the information that I was looking for. I don't normally write to forums like this, but I'm so grateful for the information and I'm hoping it will help others as well.
          As described toward the end of the above thread, the firmware needed to be updated to resolve this issue. I sincerely appreciate the link and instructions given by capkid and the clue from nomoresonys that you don't need to see a picture on the screen to resolve this issue. Using those two comments, helped me tremendously.
          However, I still sturggled to make this work so if you're struggling too, don't give up cause in the end, it'll save you hundreds or thousands of dollars in buying a new tv.
          Anyways, here's what I learned after looking at capkid's link:
          1) It's important to do the fat 32 format thing. I thought I could just do a simple format but figured out that's not the case. Apparently, fat 32 allows the usb to work with tvs and other special devices. Anyways, just google how to format a usb to fat 32 and you'll get the info.
          2) It seems that not all usb drives work. I spent almost a full day working with one usb and thought I was done for, but in desperation, I formatted a different usb to fat 32, did the instructions from capkid and it worked!
          3) I'm not sure if the way to unzip the files had to be done in any particular way but I tried it first by just right clicking on the file and extracting it. That didn't seem to work and I knew this cause the icons weren't fancy, they were pretty plain looking. Then I tried winzip which was more complicated than I wanted it to be (I was working on this for hours so I was ready to get this done!). Then I used File Extractor and it was super easy and did what I needed it to.
          So I sincerely hope this additional information helps others and prevents you from being discouraged. It was worth the 7 hours that I put into figuring this thing out cause I really didn't want to or have the money to spend on a new tv. My spouse would've appreciated it though! Good luck!
          • Agent24
            I see dead caps
            • Oct 2007
            • 4973
            • New Zealand
            Good to hear!
            -David VanHorn
            • capkid
              • Oct 2010
              • 1339
              Nice. Glad to be of help.
              • nkhilji
                • Aug 2015
                • usa
                #27
                This story is just amazing. So I picked this kdl52s4100 last Sunday for $21 at an estate sale. The sign on it said that it did not work. The green light would come on and that was it, no picture, no sound. I thought 'what the hell, I will check it out and search the internet for some ideas, if it does not work, I will junk it and only be out $21 but at least I had my fun'. So Monday (yesterday) I do a google search and land on this forum and read the advice for updating firmware. I honestly did not believe until the other guy who tried it reported that it worked. So today I thought let me try and I have many extra flash drives. So I followed the links and downloaded the software and followed the instructions of putting the usb in the tv and waiting around till the timer light blinked ember and the power light blinked green. Shut the tv off and then on. Voila! the picture came on!
                I was so amazed that I registered on this forum just to thank you gentlemen, the one who gave the advice, and the one who took it. I am an economist and I make assumptions all the time about peoples behavior, about markets, about governments, etc. Cheers and I wish I could buy you huys a drink.
                • capkid
                  • Oct 2010
                  • 1339
                  $21...very nice. Glad you were able to get it working.
                  • Rickig
                    • Mar 2015
                    • 112
                    • England
                    #29
                    Capkid any chance you have the update for a kdl-40w5810 I am experiencing the same symptoms with my set.
                    • capkid
                      • Oct 2010
                      • 1339
                      This may work: https://www.sony.co.uk/support/en/co...sa/KDL-40W5810
                      • Rickig
                        • Mar 2015
                        • 112
                        • England
                        #31
                        No
                        Already tried that. Doesn't even try to update with that file. I assume it needs to be told to look for it...
                        • capkid
                          • Oct 2010
                          • 1339
                          No
                          The TV should find the software if you've installed it at the USB drive's root. Did you format the drive? FAT32 for S4100's - not sure for your set, but I assume it's the same.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            No
                            Not sure if you saw this
                            • jazzco
                              • Dec 2015
                              • 5
                              • N.O
                              #34
                              I cant download the instructions can someone post them please I have the same problem
                              • jazzco
                                • Dec 2015
                                • 5
                                • N.O
                                #35
                                I got the instructions but it didn't up date. what can I be doing wrong? turned the TV off put the usb in turned it on the power light comes on but not the timer light (I waited longer than 20sec) like its not seeing the usb firmware
                                  Did you format the stick with FAT32?
                                  I also kept the firmware and the instruction here:
                                  https://www.badcaps.net/forum/showpo...&postcount=145
                                  • jazzco
                                    • Dec 2015
                                    • 5
                                    • N.O
                                    #37
                                    I did all that but same thing over and over again
                                      You see post 24 about the memory stick?
                                      • jazzco
                                        • Dec 2015
                                        • 5
                                        • N.O
                                        #39
                                        I tryed 2 different drives format fat32 I must suck this seems so easy
                                        • jazzco
                                          • Dec 2015
                                          • 5
                                          • N.O
                                          #40
                                          Its not see that I have a drive in any info on that?
                                          • KYBOSH
                                            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                            by KYBOSH
                                            Previous owner said TV just went blank one day.
                                            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                            I just downloaded the Sony KD-75X7800F Service Manual and...
                                            11-19-2024, 10:12 AM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
                                          • ryandesign
                                            Sony Bravia KDL-40v4100 has no picture but has power, backlight, and sound
                                            by ryandesign
                                            Hello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
                                            05-30-2021, 01:07 PM
                                          • DKWS89
                                            Sony XBR 49x900E - Sound and backlight on but no picture
                                            by DKWS89
                                            Hey Guys,
                                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                            12-14-2023, 04:30 PM
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E NO SOUND
                                            by x_orange90_x
                                            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                            Has anyone else had this happen to their tv?
                                            10-05-2024, 05:01 AM
