Bad transformers in power supply
  • Cosmo66
    • Nov 2012
    • 87
    Obviously this is a question for the more experienced technicians here -
    I was wondering if you've ever found a transformer to be the cause failure in a power supply. If so, how can you can troubleshoot these and find a replacement?
    Thanks!
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Bad transformers in power supply
    5vsb transformers in Antec SmartPower power supplies have been reported to fail. I don't know the reason of failure and how you can easily test a transformer to see if it is bad...
    • HooF
      • Nov 2012
      • 20
      I think there are a few panasonic models that blow thirmal fuses.. Check you tube for them.
        You need ringer tester for finding out if it has shorted turn. What is the power supply not doing? Turn on and then shutdown? Blowing fuse or MOSFET? I have yet to replace the transformer in the power supply, but I did replace a lot of high voltage transformers.
        • Cosmo66
          • Nov 2012
          • 87
          I was just asking a general question. I've never bothered to check a transformer in a power supply for two reasons.
          1. I"ve never had a reason to suspect a faulty one
          2. I wouldn't know how
          I was just wondering how often they might fail, and what the more experienced guys here have seen
          • randtek
            • Oct 2011
            • 280
            • US
            In TVs, I haven't seen one bad in ANY flat panel type TV. I saw a few years ago in CRT sets. You will occasionally see a bad power transformer in audio systems, due to the high power requirements of high wattage receivers. Those failures can usually be found by continuity testing. Most often the primary winding opens up.
            • Ashroyer05
              • Sep 2013
              • 162
              • U.S
              Can anyone tell me how to post a new thread?
