This is a great venue. Thank you so much for what you do.
Vizio amber light is on when plugged in. Does not turn to white with power button. no backlight. Looked for leaking caps..did not see any obvious ones.
Downloaded the manual, and read through the forum. made the measurements below:
Power supply board:
+5.16V present, 12V pins=0, 24V pins=0
PSON voltage on J1 pin 1 = 0 (45 mV)
Main board:
U22: pin 2 =3.321V; pin 3=5.17V (working?)
Both ends of F1=5.17V, both ends of F2=0V
power off: F1 and F2 are both 0 ohms.
so does this mean the 3.3V needed on J1 pin 1 is getting dropped somewhere between U22 and F2? what should I check next?
Power supply board:
Main board:
