Vizio 42" XVT3D424SV No Pic. Vizio Standby flashes 31 to 63 times after unplugged
  • MisterD
    • Oct 2012
    • 668
    This is a 42" Vizio LED/LCD Model XVT3D424SV, when first plugged in the vizio standby light flashed from orange to white 31 times,then later it flashed 63 times, but if you leave it plugged in that doesn't happen, it will power on after you wait for the light to stop flashing then it's in standby and the light stays orange, it has backlight only with no picture, so far I have only checked voltages on all visible small fuses on both main board and T-con board and I Do have voltages on both sides of all fuses.
    Main Bd. F1=11.96V, F8= 18.35V and F1=11.96V
    T-Con Bd. F4= 5.15V, F5=11.96 and F6=11.96
    attached some pictures I got off the internet but the boards are all the same part numbers as what I have in this Vizio Model.
    I'm wondering if it's the eeprom problem, any help would be appreciated.
    Thanks in advance.
  • MisterD
    • Oct 2012
    • 668
    Re: Vizio 42" XVT3D424SV No Pic. Vizio Standby flashes 31 to 63 times after unplugged
    Thanks in advance.
    If I leave it plugged in and the logo/standby light stops flashing, it goes to normal standby orange light, it will then power on but does Not have a picture, but does have back light. Hopefully someone will help me diagnose and fix the problem. I'm thinking it may be a component failure on the T-con Board but not sure, anyone willing to help? Thanks!
      What happen if you disconnect the cable to the T-CON board? These new Vizio may have EEPROM/FIRMWARE problem.
      • MisterD
        • Oct 2012
        • 668
        Disconnect which cable? Do you mean Ribbon Cables? they are connected as follows: One to power supply, one to Mainboard, and two under shield appear to go to the LCD Panel. Is there only one to disconnect?
          How many ribbon cables are there that go to the T-CON board? Since this is 3-D TV the setup may be more complicated than normal.
          • MisterD
            • Oct 2012
            • 668
            The T-Con board is in the middle but at the bottom on this model, it has 2 larger ribbon cables coming out of the bottom they are both under the metal shield, it has one smaller one going to the power supply board and then one medium size going to the mainboard
            • MisterD
              • Oct 2012
              • 668
              you can see in far right picture in first posting where the ribbon cables would go if connected, other 2 go under shield.
              • MisterD
                • Oct 2012
                • 668
                I disconnected 2 ribbon cables, one from T-CON to Power Supply board, the other from T-CON to Mainboard, had same symptoms with flashing standby/logo light, after flashing stopped TV powered on with nothing no backlights or anything just the white logo, hooked ribbon cables back up and same as above except backlights are on as they were in the beginning.
                • MisterD
                  • Oct 2012
                  • 668
                  I'm going to bed to get some sleep, will be back here tomorrow.
                  • MisterD
                    • Oct 2012
                    • 668
                    Is it normal for the newer vizio's to have a blinking logo light after they have been unplugged? Is that some sort of boot process? or is it some kind of error code? Where is the eeprom located? I will buy a new board if necessary but would rather repair at a component level if at all possible. It does power on but no display, has backlights only. can anyone please help with this? I appreciate any help I can get. Thanks!
                    • ecking767
                      • Oct 2009
                      • 492
                      Yes its normal for the "VIZIO" logo to blink for about 15 - 20 sec if the TV was un-plug. The eprom chip could be under the heat sink or on the solder side of the board. Its most like to be TSOP-48 flash memory chip. This doesn't sound like a eprom problem because the Tv turns on.
                      • MisterD
                        • Oct 2012
                        • 668
                        Re: Vizio 42" XVT3D424SV No Picture, has Backlight.Help Needed.
                        Okay, Thanks for the help, I really appreciate it..I'm thinking it may be the T-Con board that's bad but I need more information to troubleshoot it, do you
                        know of any method to isolate which board has the problem.
                        Thanks again.
                        • MisterD
                          • Oct 2012
                          • 668
                          This is a 42" Vizio LED/LCD Model XVT3D424SV, when first plugged in the vizio standby light flashed from orange to white 31 times,then later it flashed 63 times, but if you leave it plugged in that doesn't happen, it will power on and off after you wait for the light to stop flashing but has backlight only with no picture, so far I have only checked voltages on all visible small fuses on both main board and T-con board and I Do have voltages on both sides of all fuses.
                          Thanks in advance.
                          corrected some text.
                            The 31 or 63 flashes are probably the standby caps discharging (they will run a TV in standby for a very long time), I doubt they mean a code.
                            • MisterD
                              • Oct 2012
                              • 668
                              Thanks Tom, now If I could just figure out the problem, I'm thinking of ordering a T-Con Board since this is a newer model TV and there has only been one other same model vizio on this forum that had a problem, although the symptoms were different he had a bad T-con board.
                              • MisterD
                                • Oct 2012
                                • 668
                                It has 4 ribbon cables total, the 2 larger ones appear to go to the LCD Panel, one small one to Power Supply board, and one medium size to Main board.
                                • Thunder88
                                  • Nov 2012
                                  • 6
                                  • United states
                                  I know this is an old thread, but did you ever resolve the issue? I have the 55" model (xvt3d554sv) and am experiencing a similar issue. I have no sound or image, though yesterday after doing the 30 second reset I got the logo on screen for a couple seconds before the set locked up, flickered the backlight and shut down.
                                  My voltages are the same as yours on the main and t-con boards, though my backlight will sometimes flicker before the set kicks off. My inverter board tests 28.5v on both f1 and f2. I noticed something odd on my tv though; it keeps cycling like its trying to fire up. While the logo is flashing (orange/white) the 12v power is off, 5.1v is still present. When the logo just lights up white every 90 seconds 12v power is present and the blue leds on the inverter board are lit (led1 on, led2 flashing).
                                  As of right now, that's all the tv does. Even with a 30 sec reset it just flashes, I turn it on and the cycle begins. Any suggestions or a service manual link would be greatly appreciated. Thanks!
                                  • audiofreak19
                                    • Apr 2013
                                    • 556
                                    • usa
                                    Did anyone figure anything out with this tv.
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      Sorry but if I remember I somehow had two different postings about this tv set, anyway just so people know it was the T-con board that was defective and I'm still using this TV 2 years later with no problems, it is normal for this model to have a flashing Vizio logo if the set is unplugged or loses power, it will flash many times.
                                      • joto1000
                                        • Nov 2015
                                        Is there a Vizio error code manual out there that may be cross referenced with the number of times the Vizio logo flashes? I have a three year old M470NV where the picture froze, but sound kept streaming. Then after a few minutes the screen went black and the Vizio logo began flashing from orange to white 24 times and continues that cycle. I've unplugged the tv for hours and days and it still has not resolved itself. I'm assuming that the number of times the logo flashes may be an indicator of what the problem is? Thanks.
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • p-top
                                          Vizio, E60u-D3, no standby light, no ps_on
                                          by p-top
                                          Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                          main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                          PS voltages
                                          1 VSNS -2mV
                                          2-5 LED-OUT -2mV
                                          6-10 GND -2mV
                                          11 +16VS 16.29V
                                          12 AC-DET 3.929V
                                          13PS-ON -3mV
                                          14 +16VS 16.29V
                                          15 +16VS 16.29V...
                                          11-27-2023, 10:44 AM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
