No Standby voltage 26" Sabre LCT260BKA
http://www.badcaps.net/forum/showthread.php?t=39740 -
Re: No Standby voltage 26" Sabre LCT260BKA
You could weld them back together. If you were really, really careful.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I've built my own heatsinks before out of big sheets of aluminum
To add to the topic, yes, those were crap caps you got.Muh-soggy-kneeComment
I think im going to shelf this tv for awhile and see if my finacial situation changes, as Im not able to invest much into this tv. I was checking online about this tv and seems that every place i checked says this brand and model is pure junk. It was given to me and I was just going to try to fix it to use it as a pc monitor. I want to thank each of you for all your wonderful help and advice.Comment
after replacing these, however, my problem persists. What should I do next?
Thanks!Comment
hey, I'm new to this, but have a similar problem. When I plug in my TV, the light doesn't turn on. In looking at the power supply, I replaced all of the obviously blown capacitors on the right hand side, as well as, after reading this post, the "start up" ones indicated, one of small ones which was apparently blew slightly out of the side.
Thanks!Comment
You have the same exact and exact same boards used in your TV?
It is best to upload good clear pictures of YOUR boards and the whole backside of the TV so we can see all the boards.Never stop learning
In looking at this thread, it seems to be 4 years old, is it even worth trying to repair this tv, which is, itself, almost 9 years old? I like it because it's 1080p and I've had no problems with dead pixels or anything, and don't really want to buy a new TV when my fiancee has a much nicer (and larger) one that I will be able to use in about a year (and we don't need 2 TV's)Comment
"sorry, what i meant to say is the light turns on, but the TV doesn't turn on with the power button" So after replacing the startup cap in the standby power supply section now you do have 5VSB?
Which one of these is your power supply board? You need to look at the barcode sticker as shown in SJ site.
http://www.shopjimmy.com/catalogsear...ult/?q=MLT666B
Unless you want to learn about repairing, the 26" off brand is not really worth anything if it will need lots of parts to get it going.
BTW, did you also replace the caps under the heatsink? It is bad design to put caps inside the hot heatsink.Never stop learning
I have currently replaced the circled caps in red, including the ones under the heat sink (which i took off and put back on) with identical or higher spec (the blue one was the only one in which i didn't replace it with the exact same. same uf, but higher voltage, which research led to believe was OK) . I am not sure how to test if i have "5vsb" - but I do have a multimeter, so if you can describe how to test I will follow instruction. When i connect everything together, I get power to the led "on light" (red, standby light. when the tv used to work, it would turn on and the light would go green)
re: the board is a megmeet MLT666 rev. 2.5.
it shares the same code as below
http://www.shopjimmy.com/megmeet-mlt...pply-unit.htm#
but the pictured one has rev. 2.8.
I actually am interested in learning to repair, but if it is not even close to cost effective /extremely time consuming i can figure something else out. However, I am enjoying the learning experience, so i'm willing to sink another 20$ and/or 3-4 hours into it.Last edited by smattin1; 04-08-2016, 04:41 PM.Comment
Assuming...7 Photos -
This specification for the Gigabyte Sabre SABRE 17 - P47K V8 C35W10-FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SABRE 17 - P47K V8 C35W10-FR boardview and SABRE 17 - P47K V8 C35W10-FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 07:05 AM
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... -
I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
...04-08-2024, 08:04 AM -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... - Loading...
