Need Help Identifying An SMD Diode
  • ghiotom
    • Oct 2012
    • 41
    The markings are F4 5D and it's about 4 mm long. This is on a Samsung Y sus board. There are 4 or 5 of these spread around on this board. Google couldn't help.
  • gilly1984
    • 751
    Re: Need Help Identifying An SMD Diode
    Possible? http://www.marsport.org.uk/smd/mainframe.htm
    Marked C2V4 TO C75 (E24 series) BZV55 series 500mW zener diodes (2.4 - 75V)
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • drpj23
      • May 2012
      • 528
      What is the part number of the Y-Sustain?
      • ghiotom
        • Oct 2012
        • 41
        The markings on the board are D5019 so I don't think it is a zener. The board is LJ-02317A.
        • gilly1984
          • 751
          Are you sure thats the model number?
          Is it LJ41?
          • drpj23
            • May 2012
            • 528
            LJ92-01046A has a similar layout to the picture and has what you gave me on the board somewhere
            • ghiotom
              • Oct 2012
              • 41
              I'm sorry, I'm an idiot. Indeed it is LJ41-02317A.
              • gilly1984
                • 751
                I still get a zener
                Part number MMSZ5239B
                Try this pdf
                  F4 5D sitting horizontally is Diode D5019 in series with 10 Ohm resistor, the Zener diode ZD5005 is sitting vertically as shown in the picture in post 1
                  Can I see zoomed out picture of that section? It looks like it is part of the snubber circuits or rectifier for the power supply.
                  • gilly1984
                    • 751
                    Can we ask why you need to know this? Whats the problem?
                    I see the markings Bud, just all i can find with them markings are zeners?
                    • ghiotom
                      • Oct 2012
                      • 41
                      Thank you all for your very timely help. The diode in question is actually in this photo. The previous shot was a diode with similar markings that I was able to get a clearer view of, so I apologize if that confused things. I lifted one leg of that diode thinking there was a short and the other leg kind of snapped off. If I had been observant, I would have noticed that it is in parallel with that fuse and 5.2 ohm resistor and thus the low reading.
                      • gilly1984
                        • 751
                        So where does this leave us? Have you solved your problem?
                        • ghiotom
                          • Oct 2012
                          • 41
                          Unfortunately, I don't know what I can use to replace it. All I know is that it is a diode. Like I said I need to replace it after the leg snapped off right against the body of the diode.
                          • gilly1984
                            • 751
                            Flow some solder on to it, then check it with diode test on dmm, if it checks out stick it back on.
                            • ghiotom
                              • Oct 2012
                              • 41
                              Ultimately, that's probably what I'll have to do, but since I'm waiting for some parts to come in, I can wait and see if anybody else has any other ideas.
                              • Duncanbest
                                • Jul 2012
                                • 81
                                • Taiwan
                                F4----EC11FS4 xx-----date code
                                datasheet
                                http://www.alldatasheet.com/view.jsp?Searchword=EC11FS4
                                Picture (description 5A is wrong , only 1A in datasheet)
                                http://detail.china.alibaba.com/offer/759709272.html
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  1A, 100v, high speed switching diode. Look for a trr time of MAX 4ns.
                                  T
                                  veritas odium parit
                                  • ghiotom
                                    • Oct 2012
                                    • 41
                                    Duncanbest, I don't know how you came up with that, I looked everywhere, but I am impressed. I'm guessing that a lot of these common parts are made by Chinese companies with unconventional designations. I noticed some MOSFETs with numbers that I couldn't find any information on. I want to thank everyone for helping me out.
                                    On Edit: I guess this is a Japanese company according to the picture.
