17PW20 PSU problems (From Finlux 32FLD760 TV)
  • Lethagized
    • Feb 2013
    • 5
    Re: 17PW20 PSU problems (From Finlux 32FLD760 TV)
    It's a JVC LT-32DY8ZJ. Estimated to be manufactured around 2007 ish. I always thought JVC were a decent brand, but after this and sharing parts with goodmans, bush, etc, i'm well and truly put off now.
      They used to be decent. Their CRTs were made in the UK at one point, joint partnership with Thorn. Excellent build quality. My dad had one (28" basic model), lasted him 7 years, gave it to the neighbours when the 50" NEC plasma was fixed for him. Probably still working today.
      Now they've turned into a name.
      But don't worry: Sharp and Toshiba do this, too. And Hitachi. And Sanyo.
      All of the Japanese brands, except Panasonic, and Sony, are now rebadging tat. Apparently LG is offloading their lower end to the re-badge market too. Samsung aren't doing that yet, but they have their own issues with build quality...
      So you get the same build quality in a 2011 onward Toshiba/Sharp as you get in a Bush or Alba! And yet, they're £70 extra?!
      • Lethagized
        • Feb 2013
        • 5
        Some sony tv's used to me made in wales IIRC, but i read an article about them a few weeks back going on about how they're going downhill fast, so it looks like we can only hope that out of the japs, panasonic is the only company left that makes decent stuff after pioneer stopped making plasmas.
          I'm sitting here watching an awesome 46" Panasonic full HD plasma (2008-2009 generation.) "Wow" barely describes it.
          Sony didn't invest in making plasma technology commercial: if you look back, they have a lot of older patents and design marks. But they decided to use NEC and LG panels instead.
          And basically Sony is Samsung tech at a price premium, better build quality but not as good as Panasonic. So they're kind of stuck with no unique technology.
          This is happening partially due to the economic downturn & "sort by lowest price" I guess.
          This didn't happen with CRTs. The smaller brands (Toshiba, Sharp, Hitachi, Sanyo and JVC) still made their own sets. Usually imported picture tubes, but the electronics were their own or co-designed. I'm not sure why LCDs are different.
          • ron77
            • Dec 2012
            • 63
            • united kingdom
            Pull Psu from tv. Power on is 0v. All voltages will appear off load if psu is working. Of course you have to route the mains to Psu. Simply pull psu from set and connect mains. That is all you have to do.
            • toerag
              Toerag
              • Jul 2013
              On a note, there is a repair kit for the Vestel 17PW20 power supply that is 'supposed' to fix backlight and standby problems.
              It consists of the following, so you can assemble the kit yourself.
              C877 15nF 1600V polyester
              C878 15nF 1600V polyester
              C801 33uF 63v 150deg C
              C892 100uF 50v 150 deg C
              C817 220uF 25v 150 deg C
              C901 4.7uF 50V 150deg C
              IC829 or Q809 ( whichever is fitted ) 78L05 or BC337
              Kit is available from sparedparts.com but with the list above you can make your own kits up. It is for standby and backlight fault symptoms. These PSU's are used on so many sets, it is unbelievable.
              Terry.
              • toerag
                Toerag
                • Jul 2013
                Typo in parts list...caps are 105 degree C instead of 150 degree C
                • shaunbt123
                  • Nov 2012
                  • 119
                  • uk
                  #28
                  Hi all
                  just letting everyone know in case its of help to anyone with the 17PW20v2
                  board.I bought a jvc LT-32DY8ZJ,the fault was when the power button was pressed the light on the front blinked red for a second then went out,there was no power to the tv,i replaced c877 and c878 and now the tv works perfect.
                  hope this may be of use to someone.
                  shaun.
                  • bongodrummer
                    • Aug 2013
                    #29
                    Hi guys. Just registered, sorry to drag this thread back up but I have the same problem (TV not able to go on from standby - it flashes for a second as if about to turn on but then doesn't). TV has the same 17PW20.1 PSU
                    I thought it was likely that the caps C877 and C878 were gone, but upon removing from board and testing with a multimeter they are both reading very close to the value specified by toerag (15nF). My question is, is the multimeter a reliable test? Could it be reading correctly on the mm, but then be failing in some way in actual use?
                    Apart from that I would really appreciate advice on what to test next?
                    Many thanks!
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #30
                      I dont trust testing caps with anything but an ESR reader tbh.
                      I'm just about to dig into one of these PSU's too.
                      Not intermittent on the fault but perm... powers to standby and does nothing else at all... Lovely buzzing from the PSU hence I have it on my lap
                      • alvawilliams
                        • Jun 2012
                        • bridgend
                        #31
                        Originally posted by emardee
                        so if i need to "pull stby low" to power psu up outside the tv, what would be the easiest way to do this?
                        Mike
                        17pw20.1 earth pin6/pl803 to force 24v/3v3 to start
                        • johnwm
                          • Oct 2014
                          #32
                          hi has anybody got a drawing for the 17PW20 V1 010507 PSU?.I`ve tried the link from another post but it doesn`t work
                            See HERE
                            http://www.toms-service-manuals.com/...&Search=Submit
                            • jean luc ferre
                              laptop hp g72 b52sf screen problems
                              by jean luc ferre
                              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                              06-07-2025, 03:27 PM
                            • Hondaman
                              USB problems?
                              by Hondaman
                              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                              08-12-2024, 03:26 PM
                            • clabr
                              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                              by clabr
                              Need help to solve some problems with this laptop.
                              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                              Before this had happened I observed some other problems:
                              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                              12-02-2021, 08:09 AM
                            • piernov
                              Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                              by piernov
                              Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                              I suspect corrupt firmware but I haven't been able to find anything for this TV.
                              TV model: Finlux 65-FUC-8060
                              Mainboard: Vestel 17MB130S 23473048
                              Panel: VES650QNTS-2D-U11
                              At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                              06-01-2024, 12:57 PM
                            • jean luc ferre
                              display screen problems after changing motherboard
                              by jean luc ferre
                              First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                              I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                              Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                              Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                              09-11-2025, 10:28 AM
