samsung le32A457 showing vivid pinks and greens
  • philipwood600
    • Oct 2012
    • 12
    Recently replaced the t-con board on the above mentioned Tv as it had sound no picture. Problem solved but now is showing really bright neon pinks and greens around the image (i.e if a person is on the screen most of them will be neon colours but can also see normal colours.) Have uploaded a pic to help explain. hope somebody can help.
    thanks in advance
    Re: samsung le32A457 showing vivid pinks and greens
    Did you try reseating the ribbon cables already? And also, match the P/N on the barcode sticker of the original to the new one?
    • philipwood600
      • Oct 2012
      • 12
      the original t-con board i had did the same thing but as i had changed the 3 amp fuse on the board I just assumed i had damaged the board in some way. i have reseated the cables but still the same.
      • drpj23
        • May 2012
        • 528
        Make sure LVDS is good and not pinched either between framing.
        Try a factory reset?
        INFO --> MENU --> MUTE --> POWER
        or
        MUTE --> 1 --> 8 --> 2 --> POWER
        and find the reset option
        • freakaftr8
          • Oct 2012
          • 3743
          Looks like wrong diagnostic. I ran into this changing a mainboard in a 32" Polaroid. If you turn down the brightness and contrast way down but to the point you can still see the screen does it clear up?
            I think TOM66 had this problem similar to what you are having right not, try DRP suggestion, I think that's what Tom did.
            • freakaftr8
              • Oct 2012
              • 3743
              It's a mainboard issue.
              • philipwood600
                • Oct 2012
                • 12
                no still the same just darker
                • philipwood600
                  • Oct 2012
                  • 12
                  or
                  unfortunatly this didnt work either have put in another main board and still getting the same issue could it be the ribbon cable thats u/s the one from main board to t-con board.Or should I give it up as a bad job.
                    Panel setting needs to be changed. I have seen this on the LE40A656 when panel setting is incorrect for whatever reason.
                    To change panel setting you need to access this page:
                    http://img27.*************/img27/4972/resim003wah.jpg
                    Then select "Control", I think - LVDS setting should be under there. Change it to the other mode (I think there are only two) and see if it fixes it.
                    • philipwood600
                      • Oct 2012
                      • 12
                      Tom you are a star
                      There where 3 options
                      1. Default Which is the one causing the problem.
                      2.VESA which was also the same
                      3. JEIDA which cured the problem.
                      Thanks again tom
                      And Thanks to everyone else for your ideas apreciate it.
                        Originally posted by philipwood600
                        Tom you are a star
                        Thanks again tom
                        Fantastic, glad that you fixed it.
                        No idea how it got confused in first place - perhaps setting corrupted by whatever caused the T-con to die. (Though Samsung T-cons seem to be unreliable.)
                          I knew Tom fixed this problem before, I am glad he remembered it.
                            I don't think I've had the problem myself but I did deliberately enable "funky colour mode" to test the T-con on the LE40A656.
                            • Track4207
                              Hisense H50N5300UK reboots when showing full red images
                              by Track4207
                              Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                              What happens:
                              • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                              • The problem image is displayed very briefly, then the
                              08-30-2023, 11:58 AM
                            • huzo
                              Lenovo y700 not showing battery charge state
                              by huzo
                              The above mentioned laptop with the board NM B-163 is showing 1% battery charge in OS,but the battery holds for about 2h when unplugged from the charger ....when plugged in the windows says plugged in,the voltage goes up from 13.6V when empty to 15.7V when full,nominal voltage is 14.8V for that battery....SO it does charge and it does deplete, but it doesn't show charging or goes up from 1% on the battery meter....Here is the schematic for the battery charge connector, how should i test data and clock lines? They are connected to the EC on the mentioned pins,so no brekage,i don't have an oscilloscope...
                              Today, 07:36 AM
                            • Prabuth
                              always showing this message AC adapter = Unknown
                              by Prabuth
                              The customer gave me this for changing the old battery, and then I replaced the new battery. always showing this message. I changed many chargers and programmed the new BIOS as well. Does someone have any idea for this message?
                              08-28-2025, 01:26 AM
                            • seesea1393
                              Surface laptop go ME version showing 0.0.0.0
                              by seesea1393
                              The ME firmware version is showing 0.0.0.0 ,and Slow POST.Some one can Help me?surface laptop go SN: 015173404166,thanks in advance!...
                              05-11-2025, 04:23 AM
                            • Slicybtw
                              Laptop Showing no display only fan spinning
                              by Slicybtw
                              My laptop (Asus k43s) was working for a day after I cleaned its fans but then it stopped showing display (blank screen) and only would show display on a different monitor but even after booting up it doesn't let me login to my account (I use Fedora Workstation)
                              I removed all screws, it showed display but turns off after 5 seconds
                              Now it stopped working completely only fan spinning...
                              04-20-2024, 01:37 AM
