Sharp LC-32D12E Standby Light Just Flashing
Re: Sharp LC-32D12E Standby Light Just Flashing
Thanks for all your advice guys, unfortunately the problem still present.
I am leaning towards the mainboard still so have to see if i can find one for the Sharp 32". I have found several that have the right number of HDMI sockets (as tom66 pointed out to check) but they are for different makes, surely the firmware will be different forthan for this model Sharp ? I dont want to waste time & money buying one for a different make if it's not going to work properly in this Sharp.
Also, tom66, i still cant understand why i have all the outputs present when the input voltage on STBY is permanently 0v. I see the jumpers on the drawing that force the output (3v3) on but can't understand why they would want to do that.
If any one has a 17pw26-4 lying around i would appreciate it if they could check if theirs does the same
GrahamComment
I figure STBY may mean "if this pin is HIGH the TV is in standby". Otherwise, it would be PS-ON or POWER ON or similar. It would be very, very odd for your power supply to reverse the meaning of a signal.Thanks for all your advice guys, unfortunately the problem still present.
Graham
Re the jumpers - comes down to cost - will mean TV uses more in standby but the customer pays so who cares.
Re firmware - no worries with a Vestel as far as I am aware as they are all the same TV inside. There is nothing Sharp customise on these except the bezel and remote, maybe change the colours of the menus or something like that but nothing that will stop it from functioning.
Had an Alba Vestel here a few weeks ago but it's since been sold, would have checked for you as it used a 17PW26-4 and same main board. It cost about £50 less new though...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
http://www.scribd.com/doc/79274118/MB35-Training
same psu unit as yours
page 18 is worth a look at power on condition 0 volt during on condition?Comment
Thanks Tom, i thought maybe the firmware would be diferent for each maker.
Vince , thats an excellent link you gave me thank you, there's also a link on there to a page dedicated to just that PSU. It does say a high voltage (3.3v) is PSU off & a low 0v is PSU on. I should be able to check that tomorrow on the bench
i found today the service manual for the mainboard ( i will post the link here tomorrow as dont have it handy) , it says that the protect circuit will flash the front panel led if it detects a short on the supplies & it says the test point will be low if the protect circuit is operating. Well the test point is high at 3.3v so it's not going into protect but the led is still flashing. Again this makes me think it's the main board screwed up. I also notice lookig on Ebay that some of these main boards have heatsinks on the processors & some dont, well this one doesnt have one. Maybe this is why its failed.
GrahamComment
The protect either detects a microcontroller (firmware) problem or some physical hardware problem. Perhaps even corrupted EEPROM. Could be a bodged firmware update - some people pull power from their TVs while they are updating and they corrupt the firmware. Do wish though they did what Sony do which is still operate the LCD with an "update firmware using USB" screen and you can fix it that way.
The heatsink on Vestel sets is usually a joke - a piece of bendy tape that tends to fall off after the TV is a few years old. Perhaps it's a built in kill switch!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
There is an eeprom on these sets but it's SMD. Shouldn't be too difficult to replace. I built a programmer for SMD eeproms myself.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Thanks again for your help guys, i tested the PSU on the bench agai & pulled the STBY pin high via a resistor while monitoring the output voltages & they did drop so PSU looks ok. Having problems finding a suitable 17MB61-2 board though, scanned EBAY & the usual spares sites for the last couple of days but few arround. I did find this one on EBAY ,
http://www.ebay.co.uk/itm/2008218731...196%26_rdc%3D1
Problem is its from a Luxsor 40 ", the Sharp is a 32" so not sure if that would matter !
GrahamComment
do these ship to uk?
http://www.shopjimmy.com/catalogsear...lt/?q=17MB61-2Comment
Hi Vince, they probably do but at $70 plus shipping & possible import tax the owner wont pay that. You know what people are like these days, they want It fixing for nothing almost. Still it's cheper than Chas Hyde & Sons who want £277 (inc vat :-) ) .Comment
It is unlikely to matter. You may have to update the panel setting, which is easily doable under Menu 4 - 7 - 2 - 5 (the service menu.)Thanks again for your help guys, i tested the PSU on the bench agai & pulled the STBY pin high via a resistor while monitoring the output voltages & they did drop so PSU looks ok. Having problems finding a suitable 17MB61-2 board though, scanned EBAY & the usual spares sites for the last couple of days but few arround. I did find this one on EBAY ,
GrahamPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Actually i have just noticed that the board in the link has a different socket for the panel connector. Mine has the thin flat cable that you push in & then slide teh cover down to lock it & that looks like a lnormal large socket . Have to keep looking !
GrahamComment
Ah yeah, then it would be for a different screen.
You may be able to pick up a cheap set with a smashed screen and extract the main board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by JunkmanJimboHey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
by Willem01Hi all,
Error – TV not powering on - with standby red –led flashing
Model- LEDTV – 39T3500
Power boarD - shg3206a-101h
I have read through the Basic LCD TV and Monitor troubleshooting guides.
https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
Unplugged the power connector on the board, I plugged the power cable in waited... -
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
by rabbitukI have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...-
- Loading...
