Sharp LC-32D12E Standby Light Just Flashing
  • nogger
    • Aug 2010
    • 190
    Hi all, just had a Sharp LC-32D12E dropped on my by a neighbour which wont switch on , just flashing the (white ) standby light continuosly.
    Its got a Vestel PW26-4 in it & i have been all over that board (and all the previous posts on here) but i think i'm about to dissapear up my own exhaust pipe soon !
    I have 24v to the back lights on plug PL802 & 3.3 volts to the inverter board but no BL_ON signal at all. Measuring the voltages on PL816 i seem to have most voltages when switched on with a couple of exceptions as below. I can't make my mind up if this is because of a faulty mainboard (17MB61-R) or faulty PSU or is it the inverter ? As the inverter isn't getting a BL_ON i have discounted that for the moment. Voltages on PL816 with the fault condition present are:
    Pins - 1,3,5,7,9 GND
    Pin 11 - +12v
    Pin 13 - 0v (Marked as 33v on drawing but no components fitted)
    Pin 15 - 3.3 (3.3V_STBY SIgnal)
    Pins 17,19,21 - 5V
    Pin 23 - GND
    Pin 25 - 3.3V (marked as KEY on drawing ?
    Pin 27 0v
    Pin 2 - GND
    Pin4 - 8.7v (SW-SWITCH Signal)
    Pin 6 - 0V (STBY Signal)
    Pin 8 - 0v BL_ON Signal)
    Pin 10 - 3.3V (DIM_PWM_ANAL Signal)
    Pin 12 - 11.75 (+12v_1 Signal)
    Pin 14 - 5v (+5v STBY Signal)
    Pin 16 - 3.3 (+3.3 STBY Signal)
    Pins 18,20,22 - 3.3v (VCC_3v3_ON Signal)
    Pin 24 - GND
    Pin 26 - +24v
    Pin28 - 0.7-1.4 ( A/D DIM SEL Signal)
    I have changed the electrolytics even though they all looked ok, just can't understand whats going on especially the 0v on the STBY pin (pin 6) I 'm tending to veer towards the mainboard being at fault ?
    Any ideas welcomed, this is the first VESTEL PSU i have worked on & can't say i'm enjoying it.:-)
    Thanks in advance
    Graham
    1
    Re: Sharp LC-32D12E Standby Light Just Flashing
    Whenever you get a blinking LED on a Vestel it indicates a detected fault of some kind, that is the main board has sensed a problem and has shut it off. Usually it's the main board at fault. I hate Vestel TVs - although they are usually easy to fix.
    If the PSU output voltages are good I'd suspect the main board. Sadly (or is it gladly?) I have no personal experience but the boards are pretty cheap.
    http://www.ebay.co.uk/sch/i.html?_sa...17mb61&_sop=15
    You must match up the HDMI input counts and other things as there are several variants.
    One thing you could try before swapping boards is a firmware update - however I've not done this before on a Vestel TV (or any other TV) so can't offer advice.
    Shame on Sharp for using a Vestel chassis.
    • nogger
      • Aug 2010
      • 190
      Hi Tom, thanks for the quick reply.
      As i can't get the set to come up how can i do a firmware update ?
      Like i said, i'm veering to towards the mainboard.
      Graham
        I think you have to do it through the headphone port or VGA port with an adapter cable... not sure if they provide it openly - think it is for service techs only. Does the TV have USB?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          check this found on another post
          D881 (893) s/c. Print side there is a 0 ohm smd link o/c. .
            Vince is that main board or power board?
            • nogger
              • Aug 2010
              • 190
              HI Vince, i checked the diode (UF5402) by removing & measuring it, it checks out ok. also the O ohm link is ok.
              I have read all the posts on here that i can find to do with this vestel board ,I just wanted to run those voltages past someone (fresh pair of eyes and all that). Anyone have any thoughts on the voltages i posted especially the STBY pin (pin6) .
              Graham
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                https://www.badcaps.net/forum/showthread.php?t=19260
                http://www.tv.quuq.org/index.php?ind...n_view&idev=42
                also check IC830(FAN7711N)
                and this may be of help?
                After 5 failures the TV goes into failure mode and does not even try to light the lamps.
                TV into service mode to clear the error.
                To enter service mode power on while holding down Volume - and input select until a 'K' appears on screen. Then press vol- and prog- to enter service mode.
                Using the remote use the down button to select page 10/11 then use the prog button to select clear lamp error and right button to clear it.
                To exit service mode power on again with Vol- and Input Select held down
                  Does STBY change at all when it is plugged in? Or is it always zero?
                  • nogger
                    • Aug 2010
                    • 190
                    Hi Tom, with the plug from the mainboard plugged 0V, with the plug removed & measured directly on the PSU socket pin 0v & during t his time the led on the front just flashes away fast.
                    Is this pin an output or an input ?
                      Should be an output from the main board to the PSU.
                      Low might indicate TV -not- in standby - so the main outputs switched on. So this seems OK.
                      I know Vestel TVs do a self-test when first plugged in and it's likely this is failing.
                      If all the outputs are OK something else is failing on the self test.
                      I'll have a look at the schematic for the PSU to figure out whether it should be low or high.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        I worked on one of these a while ago. Have you tried holding down power and vol- for 10 seconds upon power up? Also if there's a panel short you will get these symptoms as well. Try disconnecting ribbons from tcon to panel and restart.
                        • nogger
                          • Aug 2010
                          • 190
                          Hi Freakafter8
                          unpluggedthe flat cable from the panel at the motherboard end, same problem. Also tried holding the power & -Vol, same problem.
                          Graham
                          • nogger
                            • Aug 2010
                            • 190
                            Forgot to mention, unplugged the cable to the inverter as well just for the hell of it , same again no fifference.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              did you see my edit post 8
                                The advice for clearing the errors only applies for genuine Sharp sets; these are Vestel sets so it doesn't apply.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  ah did not know that good job your up to speed on these vestel s psu
                                  • nogger
                                    • Aug 2010
                                    • 190
                                    Thnks Vince, just tried that & same same. When you say Input select i take it you mean TV/AV as it is marked on the button (next to the power switch).
                                    Graham
                                      Well, looking at the schematic, STBY should be HIGH to turn VCC_3V3_ON high. It's low though and the output's still high. However, it appears that there may be jumper links to bypass the switching.
                                      I'm thinking VCC_3V3 is a standby voltage - so it looks like it's switching correctly.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        Graham
                                        not sure myself ? copied from another site is there a select or ok key tom66 said this wont work as not a genuine sharp set
                                        http://www.tv.quuq.org/forum/index.p...e;topic=6583.0
                                        same psu
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • JunkmanJimbo
                                          sharp lc-65ub30u plays but screen is flashing on and off
                                          by JunkmanJimbo
                                          Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                                          09-07-2024, 09:45 AM
                                        • Willem01
                                          TV not powering on - with standby red –led flashing
                                          by Willem01
                                          Error – TV not powering on - with standby red –led flashing
                                          Model- LEDTV – 39T3500
                                          Power boarD - shg3206a-101h
                                          I have read through the Basic LCD TV and Monitor troubleshooting guides.
                                          https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
                                          In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
                                          Unplugged the power connector on the board, I plugged the power cable in waited...
                                          02-27-2021, 08:23 AM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • rabbituk
                                          Sony HCD BX7700dbi CMT flashing standby
                                          by rabbituk
                                          I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                          So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                          02-11-2025, 05:05 PM
