Sharp LC-32D12E Standby Light Just Flashing
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sharp LC-32D12E Standby Light Just Flashing
    Originally posted by tom66
    The advice for clearing the errors only applies for genuine Sharp sets; these are Vestel sets so it doesn't apply.
    Ah did not know that. Good to know.
    • nogger
      • Aug 2010
      • 190
      Thanks for all your advice guys, unfortunately the problem still present.
      I am leaning towards the mainboard still so have to see if i can find one for the Sharp 32". I have found several that have the right number of HDMI sockets (as tom66 pointed out to check) but they are for different makes, surely the firmware will be different forthan for this model Sharp ? I dont want to waste time & money buying one for a different make if it's not going to work properly in this Sharp.
      Also, tom66, i still cant understand why i have all the outputs present when the input voltage on STBY is permanently 0v. I see the jumpers on the drawing that force the output (3v3) on but can't understand why they would want to do that.
      If any one has a 17pw26-4 lying around i would appreciate it if they could check if theirs does the same
      Graham
        Graham
        I figure STBY may mean "if this pin is HIGH the TV is in standby". Otherwise, it would be PS-ON or POWER ON or similar. It would be very, very odd for your power supply to reverse the meaning of a signal.
        Re the jumpers - comes down to cost - will mean TV uses more in standby but the customer pays so who cares.
        Re firmware - no worries with a Vestel as far as I am aware as they are all the same TV inside. There is nothing Sharp customise on these except the bezel and remote, maybe change the colours of the menus or something like that but nothing that will stop it from functioning.
        Had an Alba Vestel here a few weeks ago but it's since been sold, would have checked for you as it used a 17PW26-4 and same main board. It cost about £50 less new though...
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          http://www.scribd.com/doc/79274118/MB35-Training
          same psu unit as yours
          page 18 is worth a look at power on condition 0 volt during on condition?
          • nogger
            • Aug 2010
            • 190
            Thanks Tom, i thought maybe the firmware would be diferent for each maker.
            Vince , thats an excellent link you gave me thank you, there's also a link on there to a page dedicated to just that PSU. It does say a high voltage (3.3v) is PSU off & a low 0v is PSU on. I should be able to check that tomorrow on the bench
            i found today the service manual for the mainboard ( i will post the link here tomorrow as dont have it handy) , it says that the protect circuit will flash the front panel led if it detects a short on the supplies & it says the test point will be low if the protect circuit is operating. Well the test point is high at 3.3v so it's not going into protect but the led is still flashing. Again this makes me think it's the main board screwed up. I also notice lookig on Ebay that some of these main boards have heatsinks on the processors & some dont, well this one doesnt have one. Maybe this is why its failed.
            Graham
              The protect either detects a microcontroller (firmware) problem or some physical hardware problem. Perhaps even corrupted EEPROM. Could be a bodged firmware update - some people pull power from their TVs while they are updating and they corrupt the firmware. Do wish though they did what Sony do which is still operate the LCD with an "update firmware using USB" screen and you can fix it that way.
              The heatsink on Vestel sets is usually a joke - a piece of bendy tape that tends to fall off after the TV is a few years old. Perhaps it's a built in kill switch!
              • nogger
                • Aug 2010
                • 190
                #27
                What would be a good idea is if they had the i2C eeprom that you just replaced (as on the Samsungs), i'm getting quite good at changing them these days
                  There is an eeprom on these sets but it's SMD. Shouldn't be too difficult to replace. I built a programmer for SMD eeproms myself.
                  • nogger
                    • Aug 2010
                    • 190
                    #29
                    Thanks again for your help guys, i tested the PSU on the bench agai & pulled the STBY pin high via a resistor while monitoring the output voltages & they did drop so PSU looks ok. Having problems finding a suitable 17MB61-2 board though, scanned EBAY & the usual spares sites for the last couple of days but few arround. I did find this one on EBAY ,
                    http://www.ebay.co.uk/itm/2008218731...196%26_rdc%3D1
                    Problem is its from a Luxsor 40 ", the Sharp is a 32" so not sure if that would matter !
                    Graham
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #30
                      do these ship to uk?
                      http://www.shopjimmy.com/catalogsear...lt/?q=17MB61-2
                      • nogger
                        • Aug 2010
                        • 190
                        #31
                        Hi Vince, they probably do but at $70 plus shipping & possible import tax the owner wont pay that. You know what people are like these days, they want It fixing for nothing almost. Still it's cheper than Chas Hyde & Sons who want £277 (inc vat :-) ) .
                          Graham
                          It is unlikely to matter. You may have to update the panel setting, which is easily doable under Menu 4 - 7 - 2 - 5 (the service menu.)
                          • nogger
                            • Aug 2010
                            • 190
                            #33
                            Actually i have just noticed that the board in the link has a different socket for the panel connector. Mine has the thin flat cable that you push in & then slide teh cover down to lock it & that looks like a lnormal large socket . Have to keep looking !
                            Graham
                              Graham
                              Ah yeah, then it would be for a different screen.
                              You may be able to pick up a cheap set with a smashed screen and extract the main board.
                              • sefoster
                                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                by sefoster
                                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                11-20-2022, 09:29 AM
                              • JunkmanJimbo
                                sharp lc-65ub30u plays but screen is flashing on and off
                                by JunkmanJimbo
                                Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                                09-07-2024, 09:45 AM
                              • Willem01
                                TV not powering on - with standby red –led flashing
                                by Willem01
                                Error – TV not powering on - with standby red –led flashing
                                Model- LEDTV – 39T3500
                                Power boarD - shg3206a-101h
                                I have read through the Basic LCD TV and Monitor troubleshooting guides.
                                https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
                                In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
                                Unplugged the power connector on the board, I plugged the power cable in waited...
                                02-27-2021, 08:23 AM
                              • STKR123
                                Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                by STKR123
                                As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                I wonder if re-flashing the BIOS might be of any use here.
                                As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                11-03-2024, 06:58 AM
                              • AstutePauciloquent
                                Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                by AstutePauciloquent
                                Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                11-23-2023, 11:02 PM
