Vizio 37" having intermittent issues
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So I got this thing broken. When I go to test it, it will turn on and function as a completely normal TV. When I hit the power button when it's cold, it will turn back on when I hit the power button. It will not after being turned on for a long time. And it will run for as long as you want until you turn it off. I brought it to my apartment to temporarily use and now it won't even turn on...All the caps look good on both the main board and the power board although not a fan of the cap choice. Is it probably the voltage regulators on the main board? I'll get my multimeter back tomorrow. In the meantime, is there any ideas to what it could be?
    Re: Vizio 37" having intermittent issues
    Sounds like an intermittent regulator though Vizio I know used some crap caps in their 37" PSUs.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yeah I'll have to check the regulators. The caps on the PSU are Sam Young on the secondary and a NCC on the Primary. Some of the Sam Young's looks like there's pressure in between the vent stamps but not bulging towards the middle, know what I mean?
      • ComputerGeek
        • Oct 2011
        • 262
        Whats the model I might have the power board? Not, for free but I'll work with you on the price.
        • retiredcaps
          • Apr 2010
          • 9271
          I prefer these types of problems rather than the intermittment ones. I have an ATX power supply that sometimes works and then dies and sometimes it doesn't power on. I wish it would just do the latter and then I can start troubleshooting it.
          --- begin sig file ---
          --- end sig file ---
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Okay so I got around to testing this thing. Let me know if there are more I need to test if I missed any. Looks like I have at least 1 bad voltage regulator...Here are the results:
            Pin 1 = 0.000
            Pin 2 = 1.252
            Pin 3 = 3.326
            Pin 1 = 2.056
            Pin 2 = 3.306
            Pin 3 = 5.050
            Pin 1 = 0.000
            Pin 2 = 0.000
            Pin 3 = 0.000
            Pin 1 = 0.559
            Pin 2 = 1.816
            Pin 3 = 3.333
            • retiredcaps
              • Apr 2010
              • 9271
              Pin 1 = 0.000
              Pin 2 = 0.000
              Pin 3 = 0.000
              1) What is the part number for #3?
              2) Are there any DC voltages on the caps around the #3 regulator?
              3) Are there any DC voltages on the resistors around that #3 regulator?
              4) Can we get a close up shot of that area?
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Thanks for the reply! Part # is: EH11A 127F25. Circled is the closest thing that gets DC power (I didn't test the caps though)
                • retiredcaps
                  • Apr 2010
                  • 9271
                  What is part number TU1? Post a link to its datasheet as well.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    On pin 3 of TU8 (regulator #3), see what it has continuity to. Namely, does it have continuity to any pins on TU1 or the caps TCE5 and TCE6?
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      All 4 of them have the same Part # on them.
                      thank you for your help so far!
                      Pin 3 of #3 has continuity to only cap TCE5
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        I mean the datasheet for TU1 (8 pin IC).
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Ohhh okay. I can't find anything on it. It reads:
                          432N
                          C0J5
                          07
                          Thank you for being patient with me
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            1) See if there is DC voltage across the TCE5 cap.
                            2) See what else is the + leg of TCE5 is connected to.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              432N
                              It could be
                              https://cdn.badcaps-static.com/pdfs/...a5f3eed1f1.pdf
                              See if pin 3 (VCC) has any voltage wrt to chassis ground.
                              • ComputerGeek
                                • Oct 2011
                                • 262
