So I got this thing broken. When I go to test it, it will turn on and function as a completely normal TV. When I hit the power button when it's cold, it will turn back on when I hit the power button. It will not after being turned on for a long time. And it will run for as long as you want until you turn it off. I brought it to my apartment to temporarily use and now it won't even turn on...All the caps look good on both the main board and the power board although not a fan of the cap choice. Is it probably the voltage regulators on the main board? I'll get my multimeter back tomorrow. In the meantime, is there any ideas to what it could be?
Vizio 37" having intermittent issues
Re: Vizio 37" having intermittent issues
Sounds like an intermittent regulator though Vizio I know used some crap caps in their 37" PSUs.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Yeah I'll have to check the regulators. The caps on the PSU are Sam Young on the secondary and a NCC on the Primary. Some of the Sam Young's looks like there's pressure in between the vent stamps but not bulging towards the middle, know what I mean?Comment
Whats the model I might have the power board? Not, for free but I'll work with you on the price.So I got this thing broken. When I go to test it, it will turn on and function as a completely normal TV. When I hit the power button when it's cold, it will turn back on when I hit the power button. It will not after being turned on for a long time. And it will run for as long as you want until you turn it off. I brought it to my apartment to temporarily use and now it won't even turn on...All the caps look good on both the main board and the power board although not a fan of the cap choice. Is it probably the voltage regulators on the main board? I'll get my multimeter back tomorrow. In the meantime, is there any ideas to what it could be?Comment
I prefer these types of problems rather than the intermittment ones. I have an ATX power supply that sometimes works and then dies and sometimes it doesn't power on. I wish it would just do the latter and then I can start troubleshooting it.--- begin sig file ---
--- end sig file ---Comment
Okay so I got around to testing this thing. Let me know if there are more I need to test if I missed any. Looks like I have at least 1 bad voltage regulator...Here are the results:
Pin 1 = 0.000
Pin 2 = 1.252
Pin 3 = 3.326
Pin 1 = 2.056
Pin 2 = 3.306
Pin 3 = 5.050
Pin 1 = 0.000
Pin 2 = 0.000
Pin 3 = 0.000
Pin 1 = 0.559
Pin 2 = 1.816
Pin 3 = 3.333Attached Filesif you find these attachements useful please consider making a small donation to the site
1) What is the part number for #3?
2) Are there any DC voltages on the caps around the #3 regulator?
3) Are there any DC voltages on the resistors around that #3 regulator?
4) Can we get a close up shot of that area?--- begin sig file ---
Thanks for the reply! Part # is: EH11A 127F25. Circled is the closest thing that gets DC power (I didn't test the caps though)Attached Filesif you find these attachements useful please consider making a small donation to the site
What is part number TU1? Post a link to its datasheet as well.--- begin sig file ---
On pin 3 of TU8 (regulator #3), see what it has continuity to. Namely, does it have continuity to any pins on TU1 or the caps TCE5 and TCE6?--- begin sig file ---
I mean the datasheet for TU1 (8 pin IC).--- begin sig file ---
It could be
https://cdn.badcaps-static.com/pdfs/...a5f3eed1f1.pdf
See if pin 3 (VCC) has any voltage wrt to chassis ground.--- begin sig file ---
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by grettiI have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
The MSI BIOS included the ME firmware for the board. The size... -
We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
I also... - Loading...
