Phillips 50" Plasma - 50PF7321D/37
  • PhillyPilot
    • Sep 2012
    Hi All,
    While watching TV at very random times the picture goes black. It still has sound and appears to still have back lighting. Not sure if this will help but when it happens all I have to do is smack the back of the TV and the picture comes back. Also sometime I get the rainbow of vertical colored lines just before it blacks out.
    I opened her up yesterday and found what I believe to be two bad caps. One is easily fixable and seems to be just slightly raised. The second (left arrow in photo) I can not see very well because it is under a heat sink. It apears to be leaking slightly. I am looking for any sdvice you might have and links to where I can purchase these capacitors.
    Thank you for any help!
    Kevin
    Picture of the board
    First Cap
    Hidden Cap
  • drpj23
    • May 2012
    • 528
    Re: Phillips 50" Plasma - 50PF7321D/37
    Here is one (and can use as an example) for the first one
    http://www.digikey.com/product-detai...2735-ND/613719
    They both look bad (from my perspective) but the fact you can hit it and it work again is strikingly odd. (sorry :P)
    But on a serious note, I would just make sure all your connectors are seated correctly, especially ribbon types.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I'd replace all of them except the big input caps, they're Samwha...they're all doomed to bulge eventually. You can leave those Samxon caps those should be good. List all the specs of the caps so we can give you proper links
      • PhillyPilot
        • Sep 2012
        Yes it is very weird! 95% of the time the TV works perfectly. But it is annoying to have to get up once or twice a day to smack the back of the TV. Yes I know this sounds lazy but its hard when you have a sleeping baby in your arms... Thanks for the link and the advice! It looks like that one is perfect for the first one. The one under the heat sink unfortunately I can not see so I will have to wait till I have time to really take it apart before I can give the specs on it.
        • gilly1984
          • Jun 2012
          • 751
          If you hit it and it comes back on then it is likely a loose connector or cold solder joint.
          Leave the back off (well away from kiddies) and when it does it again slightly flex each circuit board to see which is the problem. Use a bit of wood to do it.
          Then when you have found the board look for cold or poo solder joints.
          Do NOT touch heatsinks when testing for voltages as they may be LIVE!
          • PhillyPilot
            • Sep 2012
            Thanks Gill71984, I will have to try that. The trick will be keep my 4 year old away from it.
            • drpj23
              • May 2012
              • 528
              Oh make sure the dimensions are correct for the capacitors - that's the only criteria I couldn't match but it'll be slightly annoying when the cap is taller than the heatsink lol
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
              • KYBOSH
                Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                by KYBOSH
                Saved this beast from the landfill this weekend.
                Manfactured July 2013 in Mexico.
                I love working on plasma TVs.
                Its been a while but I was lucky enough to find 2 this week.
                The TV powers on and stays on but no picture. Havent checked for sound yet.
                No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                Will start troubleshooting tonight.
                10-17-2024, 01:17 PM
              • Bloopeta
                Phillips 58PUS7805/12 No Picture
                by Bloopeta
                Phillips 58PUS7805/12, was told it had sound no picture, sometimes picture would come back then go again?
                From what I have seen myself, its just blank illuminated screen. Tried unplugging each ribbon cable from Tcon in turn.
                When one is unplugged, I get half sceen, clear picture.
                With other unplugged, get half screen but with thin horizontal lines
                Any ideas? Or is it likely a bad panel?...
                03-10-2023, 02:08 PM
              • Uranium-235
                Phillips 50PF7321D/37 Plasma slow reboot
                by Uranium-235
                Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
                12-27-2021, 09:14 PM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
