Vizio GV42L HDTV amber light no pic only clicking rapidly
  • schwegy
    • Jan 2012
    • 15
    Re: Vizio GV42L HDTV amber light no pic only clicking rapidly
    @budm Attached are the pictures you asked for. I took three pictures of the main board (from left to right). Also attached is the picture of my inverter board showing which relay I replaced.
    I disconnected the top two white connectors and the clicking is still there. I did go ahead and disconnected the third white connector and the noise stopped. Not sure if that is helpful.
      OK, the relay is on the power supply boards, that is not inverter baord. There are two inverter boards, one on the left, one is on the right of the chassis, they are covered with metal shields. You can see two set of cable with white wires going to them. We need the pictures of those two inverter boards.
      I also like to see good clear pictures of both sides of the power supply board so I can see how the relay is driven 9more likely to be driven by the signal from the main board).
      • schwegy
        • Jan 2012
        • 15
        Ok I have Attached pictures of the inverter boards. "A" is my left side and "B" is right side.
        Also both sides of the power board.
        • schwegy
          • Jan 2012
          • 15
          Any suggestions? I have no problem working through the trouble shooting process.
            Remove the power cables from the power supply board to the inverter boards and see if the LOGO will turn from AMBER to WHITE when you turn the TV on.
            • Worminizer
              Telephone Guy
              • Aug 2012
              • 51
              My voltage reg replacement worked! Tv powers up and all functions are normal. You guys are once again awesome.
              Thanks again
              • schwegy
                • Jan 2012
                • 15
                #27
                With both inverter boards unplugged and leaving the main board connected to the power board the logo stays amber and the clicking continues. When I disconnect the main board from the power board the clicking stops.
                  That means the main board is causing the problem, the main board sends the on signal to turn on the relay. So back to checking voltages of the LDO regulator IC's first.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    How about testing the PS with a bulb/resistor?
                    • Sisko
                      Onkyo-593 No power and now clicking sound
                      by Sisko
                      Hi all!!
                      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                      10-03-2025, 02:18 PM
                    • B0r1s
                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                      by B0r1s
                      PSU - BN44-00878A
                      Symptoms:
                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                      A weak clicking sound was coming from the transformer.
                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                      Progress:
                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                      01-17-2023, 04:58 PM
                    • slimmy182
                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                      by slimmy182
                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                      Looking on google I found this:...
                      01-14-2023, 11:55 AM
                    • shahnld
                      Sony kdl 65xg9505 green amber blinking
                      by shahnld
                      Good Day.
                      I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                      i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                      green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                      01-03-2024, 03:05 PM
                    • huzo
                      HP 470 G5 blinking amber light no power
                      by huzo
                      The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                      So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                      I've tried flashing the bios...
                      interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                      06-08-2023, 04:08 PM
