Samsung LCD 26" full white screen
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Another possible purchase. Seller says the screen lights up white, but sound works. He's from Bucharest so i can get to see it. I'm thinking Tcon failure? Dunno the exact model but will ask him.
    A working TV? How boring!
    Re: Samsung LCD 26" full white screen
    Sounds like it. How much does he want? You could be lucky and it could just be a fuse. Samsung TVs of the older generation were very prone to blowing the fuse on the T-con.
    • crtfool
      • Jun 2010
      • 82
      I know that you can get a totally white screen if you disconnect the Panel from the T-Con, or the T-Con from the main board - I do this all the time to check the status of the CCFLs. It most likely is the T-Con that has failed.
        Should look up the model number to see if it does have stand alone T-CON or one of those LCD panel with integrated T-CON like they do on the computer monitor, they start doing that to save money.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          It got sold already.
            Darn. Seems no-one waits for anything in Romania...
            Whatever happened to that Philips plasma anyway?
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • Chrissygizmo
              samsung galaxy ao2s very temperamental after screen replaced
              by Chrissygizmo
              Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
              Ive eventually managed to get it on and working but it's very temperamental...
              The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
              05-26-2024, 12:05 AM
            • JunkmanJimbo
              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
              by JunkmanJimbo
              Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
              No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
              Please help. Thanks in advance!
              08-12-2025, 11:45 AM
