Vertical white fading lines on Sams LED
  • Jcov
    • Sep 2012
    • 9
    • Usa
    I got a UN46B7100WFXZA, Samsung led, started with thin black horizontal lines, few days later went to white/red verticle lines. Can still see pic but looks bad, what can I check?? Please help only 3 yrs old(tv)
  • Jcov
    • Sep 2012
    • 9
    • Usa
    Re: Vertical white fading lines on Sams LED
    here are some pics
      I would say T-con... common failure on Samsung TVs.
      • Jcov
        • Sep 2012
        • 9
        • Usa
        is there anyway i can test tcon before i replace it??
        where is best place to purchase tcon and manual for the particular samsung??
        thx a millon
          Do the lines affect the menu, such as the setup menu or volume control?
          Do the lines fade in slowly, or suddenly appear? After appearing, do they stay as they are, or do they fade in?
          • Jcov
            • Sep 2012
            • 9
            • Usa
            yes lines are shown on menu,settings, and all inputs.
            when first turn on tv it slowly fades in, then when watching the line fade on the left side and right side. but the white lines seem to stay. 2 days ago pic was great for only few hours but right back to line been like it since
              The only board capable of creating "fading" effects is the T-con, as far as I am aware.
              I found one seller for $56:
              http://www.ebay.co.uk/itm/Samsung-UN...#ht_1581wt_736
              That's a lot to pay - you may be able to get it cheaper elsewhere. Also, disassemble your TV and find the T-con to get the exact part code, it may be different.
              • Jcov
                • Sep 2012
                • 9
                • Usa
                wow im bout to take it apart now and check ive never worked on a tv before but im very mechanically inclinded so ill see if i can find the part number. thank u so much for ur expertise and help
                • kevinm34232
                  • May 2012
                  • 1884
                  I've had quite a few TV's where it seemed the T-Con was the culprit and that did not turn out to be the case. Without a scope could never determine whether it was the panel or main board but I suspect the main board in at least a couple times.
                  One case was a 26" LG, picture would freeze horizontally, sometimes a white screen. After heating up would work normally. Replaced t-con, same result. Sold lcd panel and power supply which worked for buyers. Last part left is main board.
                  My next tool purchase will be Tom's Rigol scope when he upgrades
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Sometimes if there are bad caps in the psu, it can cause issues with the video processing. Too much ripple can cause errors and such in the processing.
                    Muh-soggy-knee
                    • Jcov
                      • Sep 2012
                      • 9
                      • Usa
                      did not notice any bad capacitors just visually inspecting do i need to check uf on all capacitors,
                      the tcon board is 2009FA4C4LV0.9
                      • Jcov
                        • Sep 2012
                        • 9
                        • Usa
                        i was just about to order the tcon from cali they told me it could be they panel is bad and to call back tomorrow to talk w/ a tech, does that sound right the tcon was 99$ which is a lot better than a 400$ panel
                          You would need an ESR meter to check the caps.
                          I have found bad caps where the capacitance (uF) tests fine and some where it even tests higher.
                          It looks like a t-con fault, but I suppose you can't rule out the power supply - Samsung have a lot of power supply faults too. The newer ones don't generally suffer from bad caps though.
                          • Jcov
                            • Sep 2012
                            • 9
                            • Usa
                            After talkin 2 another tech he was thinking it was the panel & not the tcon, does that sound right? Is the panel a common problem on a Sam. LED. Do u think it's worth trying a tcon 1st if not I don't believe it worth replacing panel due 2 cost... Any input would be greatly appreciative
                              It COULD be the panel, but that basically writes off the TV. Panel failures usually affect only one half of the picture, not the whole picture. A t-con would be a good gamble if you saved the TV and if you can get it cheap. (Usually, t-cons are around $20 each, so you might consider making the seller an offer on it - it's worked before for me.)
                              • mbates14
                                • May 2005
                                • 169
                                its definitely a bad panel. it looks like it anyway. panel failures affect any portion of the screen whether partial or all of it.
                                Especially if the picture ghosts its 99% bad panel. Its definitely a tossup, but im betting on the panel.
                                  This where I disagree. Most people would write this Samsung TV off with a bad panel:
                                  https://www.badcaps.net/forum/attach...4&d=1333908115
                                  Especially the repeating lines, affecting the whole screen? New T-con fixed it.
                                  These two pics are budm's. Both bad t-cons:
                                  https://www.badcaps.net/forum/attach...9&d=1333492925
                                  https://www.badcaps.net/forum/attach...0&d=1333492925
                                  (Samsung panels in Sony TVs.)
                                  This video is an example of a bad panel; the problem only affects half of the screen (AUO panel): http://www.youtube.com/watch?v=purk_SyiT44&feature=plcp
                                  Bottom line is, panel failures usually only affect parts of the screen or cause screen-wide ghosting. They rarely affect the whole screen with lines - that requires multiple gate-driver ICs on the tab bonds to have failed. Now, I have less experience with newer Samsung panels - so it could be different now.
                                  • Stanley1843
                                    by Stanley1843
                                    06-29-2024, 11:54 AM
                                  • brad2157
                                    Vizio E70-E3 Two white vertical lines
                                    by brad2157
                                    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                    Replacement main board - Boots up fine, but starting...
                                    12-13-2021, 05:11 PM
                                  • Falki
                                    Colorful LCD Vertical Lines on Samsung ue55es8090
                                    by Falki
                                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                                    A similar issue has been posted as well but also with no actual response ...
                                    08-12-2025, 04:19 AM
                                  • thstuff
                                    SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                    by thstuff
                                    This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                    Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                    1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                    2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                    01-30-2023, 05:01 PM
                                  • visionbluedemon
                                    Help. Sony kd-65x85dj vertical lines
                                    by visionbluedemon
                                    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                    tried blocking LC lines too, but same results
                                    is it lcd panel issue or tcon board issue?...
                                    07-25-2025, 04:56 AM
