Westinghouse Ltv-32w6 HD No Picture
  • Fly_Among_Stars
    VIZIO E70-E3 Half picture with half TCON
    by Fly_Among_Stars
    I have a VIZIO E70-E3.
    Symptoms: Black screen, no picture, but LED backlights are working.
    I probed the power board and voltages are as listed on the board.
    Main board appears fine, too.
    I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
    There are two separate ribbon cables feeding the LCD.
    If both are connected, the screen is black.
    If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
    04-24-2023, 08:20 PM
  • iglitare
    Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
    by iglitare
    i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
    Backlight seems to work, Sound (Setup menu after reset) works.
    If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
    Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
    With my small knowledge i would think at least the cables are good.
    Can this happen because of a bad tcon board?
    Or is it always a bad/shorted...
    09-04-2025, 07:13 AM
  • shelby5041
    Samsung LCD TV no picture backlight on no 12v at tcon
    by shelby5041
    hi
    i have a samsung lcd tv
    it powers on with sound and backlight but no picture
    all voltages from PS are good 12v 3.3v and 5v
    whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
    i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
    no 12v at the tcon fuse
    i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
    the odds of having 2...
    10-08-2021, 08:21 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
