Test T-CON
  • shorteddiode
    • 221
    Test T-CON
    Is there a way to test a T-CON board other than swapping it for a good one. I have a scope but don't know what signals to look for.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Test T-CON
    I'm asking the same thing.
    • drpj23
      • May 2012
      • 528
      Re: Test T-CON
      You could try testing the signal from the LVDS cable and eliminate mian board for visual probs. You would really need a in depth training guide or something like this document I added but in a general sense, it's really hard to know what to look for (IMO) unless someone else knows a way.
      But in a general concept, you could at least check fuses and any regs on the board.
      • alltvrepairs
        Lg TCon test pins for screen test
        by alltvrepairs
        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
        Appreciate your help....
        06-13-2025, 06:33 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • chth96
        How Can I test PWM DM0365R?
        by chth96
        Hello
        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
        06-18-2025, 04:14 PM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
