Is there a way to test a T-CON board other than swapping it for a good one. I have a scope but don't know what signals to look for.
Test T-CON
Tags: None
Re: Test T-CON
You could try testing the signal from the LVDS cable and eliminate mian board for visual probs. You would really need a in depth training guide or something like this document I added but in a general sense, it's really hard to know what to look for (IMO) unless someone else knows a way.
But in a general concept, you could at least check fuses and any regs on the board.Attached Filesif you find these attachements useful please consider making a small donation to the site
by alltvrepairsHi,
i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
Appreciate your help....2 Photos -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... - Loading...
