LG Plasma 50PC1DR- Y-SUS Issues
    Re: LG Plasma 50PC1DR- Y-SUS Issues
    The SMD caps he probably refers to are the round radial silver can ones. Which have a valued printed on them. They are electrolytics.
    • cheebster
      • May 2008
      • 376
      #202
      AH ! Thanks tom66. I was wondering if i should replace them, or at least check all of them for a proper ESR value.
      I don't have a esr meter, but i could buy one if it's handy to have..
        A scope is a more handy thing to use, so save up for that first IMO.
        I find very few electrolytics (maybe two in total) that have failed without bulging.
        • cheebster
          • May 2008
          • 376
          #204
          Yes. But reading that article, it seems that the failed SMD radial silver ones that arent failed but just, old, could be the culprit of the IPM failure. Im digging a little deeper, because those fixed plasmas i got here are for my friends and i dont want them to come back. im selling them for cheap but still, i want the repairs to be reliable...
          if its just a few caps more to replace, ill do them without thinking twice
          • cheebster
            • May 2008
            • 376
            #205
            Hi tom66. I've found a site yesterday, never came across this one, has a lot of free tv service manuals.. i thought i would share !
            http://www.servicetron.com/tv-service-manual.html
            Seems to be a lot there !
              Thanks will keep it in mind.
              • jjanssen7
                • Nov 2012
                • 252
                cheebster (or anyone else), did you ever figure out if the LG IPM's are compatible with the sanyo ones? jo15b,jo15c,jo15e, jo16b,jo16c,jo16e etc?
                Thanks!
                • cheebster
                  • May 2008
                  • 376
                  #208
                  Hi there. Yes they are ! But make sure to use the good ones..
                  here's a quick x-ref i've done by searching a little, it should be right !
                  yppdj014 = STK795-811
                  yppdj015 = SPI-50X3E240
                  yppdj016 = SPI-50X3E120
                  yppdj017 = STK795-821 STK795-820
                  yppdj018 = STK795-821 STK795-820
                  yppdj019 = ???
                  yppdj023 = ???
                  • microvibe
                    • Mar 2013
                    • 275
                    • canada
                    #209
                    resureccting old thread but i have same tv and positive its y-sus, my tv powers on fine plays sound but the screen flashes on and off with ipm on y-sus clicking away. what do the 2 ipms on y-sus do exactly. one of them is humming like the ipm's on the zsus. when the screen flashes i dont see a picture or menu picture its just white noise or white and grey thin lines. i have tried with buffers disconnected as well. the tv didnt have any bad fuses the psu caps were all good and it will play a whole movie like this without shutting down. i did use the -vy vsc test points and voltages are all over the place with the clicking. these boards are pricey so i would like to repair it instead of replace but at $40 a ipm not sure if its economical lol
                    • microvibe
                      • Mar 2013
                      • 275
                      • canada
                      #210
                      actually my tv isnt same as thread title just same ysus i believe i have a 50pc3d
                        You probably have bad Y-sus and buffer boards.
                        One IPM, the one closest to the coils, does energy recovery. Makes the plasma driving more efficient.
                        The other IPM sustains the panel, the major part in making it light up.
                        • gretti
                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                          by gretti
                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                          The MSI BIOS included the ME firmware for the board. The size...
                          10-16-2025, 02:14 AM
                        • PlasMatt
                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                          by PlasMatt
                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                          09-20-2025, 06:50 PM
                        • Burglicious
                          Samsung PN59D6500 Plasma TV issues
                          by Burglicious
                          Hey all, i have a Samsung PN59D6500 that I rescued from the dumpster and I'm trying to fix it. So the issue I am having is that the TV isnt turning on at all. I have VS,VA,VSC,VE at all the appropriate voltages. I have 3.3V at the PS-On, and 5V also. Whats happening is when i press the power button on the remote the TV has has the relays click, some pixels flash on the screen and then it seems to turn off. It repeats this until the TV is unplugged. I know that the Mainboard has a problematic EEPROM but this seems kinda like a power regulation issue. Anyone have any ideas?
                          12-09-2021, 09:03 PM
                        • pixelcap
                          Pioneer Kuro Pro 111FD 8 red blink error
                          by pixelcap
                          Pioneer Kuro Pro 111FD 8 blink red LED.
                          I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                          So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                          based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                          10-06-2024, 11:26 PM
                        • SoulFreeze
                          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                          by SoulFreeze
                          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                          After repairing the above issue, I realized the following remaining problem,
                          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                          The computer recognizes headphones are connected and displays a popup in windows
                          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                          06-21-2025, 09:53 AM
