LG Plasma 50PC1DR- Y-SUS Issues
  • cheebster
    • May 2008
    • 374
    #41
    Re: LG Plasma 50PC1DR- Y-SUS Issues
    LOL !!! it took me 2 minutes to remove an ipm with this thing. guys, if you do a lot of rework.. buy one !!! best 200$ even spent on a tool. an hakko 808...
    • cheebster
      • May 2008
      • 374
      #42
      I did a test here, took IPM J016 ER from board #2, put on tv#1.
      now doesnt shut down, i see a black screen with green dots, then all white image for 2-3 minutes then shut down. image is white but with a lot of weird lines in it.. colored lines.
      bare with me here, just trying to figure out things. first time on a such thing...
      • cheebster
        • May 2008
        • 374
        #43
        okay.. found that VSC is completely off, it's oscillating between 0-10v. -YV is 223vdc..
        im using the good test points. something's completely off here !!!
          That looks like you might have a short circuit.
          • cheebster
            • May 2008
            • 374
            #45
            on the y-sustain ?
            • cheebster
              • May 2008
              • 374
              #46
              ive swapped the buffer boards, the z-sus, the j016 ipm so far.
              is vsc and -yv generated on the ysus ?
                Yes. Is the problem present with the buffers connected?
                • cheebster
                  • May 2008
                  • 374
                  #48
                  Yes. I've tried removing the buffers and it didn't change anything.
                  The exact behavior of the tv right now is, startup with black screen with green dots, then after a few secs goes to a funky white screen and i can hear sound (noise from tuner), then flashes back to black screen with green dots, and shut down.
                  -yv measure 223vdc, vsc measured from 0-10 vdc fluctuates.
                    Vsc controls the setup waveform of the panel so if it is missing you can get odd symptoms such as wild brightness fluctuations. Can you see what's connected to the Vsc and trace it out, see if there are any more shorted FETs etc...
                    • cheebster
                      • May 2008
                      • 374
                      #50
                      I'm going to dig a bit more in the service manual and that training manual to see if i can understand something...
                      I've tried 3 different ipm's on the same tv same Ysus board, and had 3 very different results...
                      But, similar is the vsc. it never changes from ipm to ipm, it's always completely off.
                      Is the vsc generated by the IPM ?
                        No, VSC is generated by that little sub board with the transformer on it.
                        • cheebster
                          • May 2008
                          • 374
                          #52
                          i restored -YV 196v, found 2 big 100 resistors again under one ipm. i missed those..
                          I guess i'm giving up until i get some new ER ipm's to test the board.
                          I will check, might be a short on the sub board !
                            VSC is bad still?
                            • cheebster
                              • May 2008
                              • 374
                              #54
                              Um - can i power one one of these plasmas without any of the 2 ipm's to check if the VSC is present ?
                              • cheebster
                                • May 2008
                                • 374
                                #55
                                VSC is bad still, yes !
                                  You should be OK on powering it up without IPMs but beware high voltage will not decay quickly on some plasmas without a load.
                                  • cheebster
                                    • May 2008
                                    • 374
                                    #57
                                    I got 120vdc at the output of the subboard. So it's doing it's job.. it's after that that vsc is being lost !
                                    • cheebster
                                      • May 2008
                                      • 374
                                      #58
                                      Is there a way to figure out (when the service manual doesn't say anything about it) the wattage value of a SMD resistor (the ones i'm looking for are marked 100, as 10 ohms..) ?
                                      Doing a search on digikey, even with the same dimensions, i get results from 1 to 16W, huge difference !
                                        Measure the dimensions and use these approximations.
                                        0.06" x 0.03" = 0603 = 50-63mW
                                        0.08" x 0.05" = 0805 = 80-125mW
                                        0.12" x 0.06" = 1206 = 125-330mW
                                        0.20" x 0.12" = 2012 = 500-1000mW
                                        • cheebster
                                          • May 2008
                                          • 374
                                          #60
                                          Okay. They are a little bigger, they seem to be 2512;
                                          0.248" L x 0.126" W (6.30mm x 3.20mm)
                                          I just have a ruler though. Is 1W sufficient for this size ?
                                          I'm still trying to find out what's shorting the 120VDC vsc after the sub board. from what i understand, this is being sent directly to the y-drive output?
                                          I see Q2, Q3 there, also Q13, 05 (can't find this Q05?).. all seem fine
                                          I'm trying to figure out what's a 4A67 diode and a 25 diode. Google results are a *bit* confusing to me !
                                          I'd really like to find out what's draining the vsc down from the sub-board that generates VSC. i see VS coming in, VSC going out, then if i check output at the VSC test points it's 0-10 volts. I don't understand !!!
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
                                          • Burglicious
                                            Samsung PN59D6500 Plasma TV issues
                                            by Burglicious
                                            Hey all, i have a Samsung PN59D6500 that I rescued from the dumpster and I'm trying to fix it. So the issue I am having is that the TV isnt turning on at all. I have VS,VA,VSC,VE at all the appropriate voltages. I have 3.3V at the PS-On, and 5V also. Whats happening is when i press the power button on the remote the TV has has the relays click, some pixels flash on the screen and then it seems to turn off. It repeats this until the TV is unplugged. I know that the Mainboard has a problematic EEPROM but this seems kinda like a power regulation issue. Anyone have any ideas?
                                            12-09-2021, 09:03 PM
                                          • pixelcap
                                            Pioneer Kuro Pro 111FD 8 red blink error
                                            by pixelcap
                                            Pioneer Kuro Pro 111FD 8 blink red LED.
                                            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                            10-06-2024, 11:26 PM
                                          • SoulFreeze
                                            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                            by SoulFreeze
                                            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                            After repairing the above issue, I realized the following remaining problem,
                                            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                            The computer recognizes headphones are connected and displays a popup in windows
                                            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                            06-21-2025, 09:53 AM
                                          • Phlox321
                                            Samsung plasma tv PS43D450A2 pixel issues
                                            by Phlox321
                                            Hi guys. I have a Samsung plasma Tv with a wierd prpblem.its a samsung plasma PS43D450A2. A little history : I got the tv free from someone as the thought the power supply was bad and was about to throw it away. I check it and found shorted x main board. I found the diodes and igbts were shorted. After a long search for components i aquired them and replaced them. The tv then worked fine for a few months and about 2 weeks ago it started showing random yellow and purple pixels only on about the right of the tv. Its clearly cisible on a white screen but not as noticeable when watching a movie. And...
                                            04-12-2020, 03:58 AM
