LG Plasma 50PC1DR- Y-SUS Issues
  • cheebster
    • May 2008
    • 374
    #181
    Re: LG Plasma 50PC1DR- Y-SUS Issues
    i forgot the board in the oven while over the phone.. lol
    this one's dead. oh well, at least ive got a replacement from the broken screen 42'' seems its the same board
    im swapping the from tsop chips right now.. cauz when installed, i had only 42'' of the screen working.. and the same blue lines
    i really dont know whats causing this thing to bug, but it's sure bugging me.
    i will check in a few minutes if it affects the menu. how can i access the white wash mode? i have no remotes (have some coming from china in a week or 2, tho)
      D'oh!
      You need to access the menu and select ISM Method (forget exactly where it is), then White Wash.
      42" is 1024x768. 50" is 1366x768.
      • cheebster
        • May 2008
        • 374
        #183
        do i need a remote, is it in the service menu ?
        eh, do you have a clue where is the panel information stored into, is it the tsop rom chips ? hehe
        • cheebster
          • May 2008
          • 374
          #184
          argh. where do you think panel configuration is stored, on that board ?
          http://assets.shopjimmy.com/media/ca...0/003_4_16.JPG
          so far ive swapped the 2 tsops ic105/6, ic602 the 24c eeprom, then ic202 over the tsop the 24c eeprom, then ic111 another eeprom.. no go
          i hope its not stored in the cpu, dammit
          • cheebster
            • May 2008
            • 374
            #185
            im still swapping chips. i really tought it was in a small eeprom..
              It might be the control board is hard wired for 42". I wasn't aware they were swappable anyway.
              • cheebster
                • May 2008
                • 374
                #187
                what do you mean hard wired for 42'' ?
                i have 2 identical input boards, with same rom versions and same components. everything is identical hardware wise so it's something programmed into either an eeprom, a cpu, a rom or any programmable chip
                i was wondering if it was configurable into the service menu maybe ? i will continue swapping chips later, need to work a bit now
                  It could be for example an option-bit burned into the main processor, which is not changeable. I don't know for sure.
                  The service menu only controls the settings on the input/main board, assuming it is the one for the 50", then it would be sending a 50" signal.
                  • cheebster
                    • May 2008
                    • 374
                    #189
                    hehe okay. well im giving up on that input board, theres one for 30$ on ebay, that will do it.
                    i guess like you said there's something hardwired for the 42 or an option into the cpu. anyhow..
                    i got another issue weeee, im gonna be good with plasma issues someday ! the issue is, that i got some lag in the picture on one i just put back together.
                    everything works.. its just the picture redraw is somehow, laggy.. its slow to be refreshed.
                    ive checked, all the voltages are present and good, i messed a bit with the vsustain voltage, didnt change much. its laggy .. what can cause this behavior ?
                      Re - lag: decrease -Vy a little, if it gets worse, increase it.
                      • cheebster
                        • May 2008
                        • 374
                        #191
                        i will try that right away. thanks
                        • cheebster
                          • May 2008
                          • 374
                          #192
                          um.. nothing i can do with pots that will fix that thing. picture looks good, but i cant get rid of that nasty sluggishness.
                            Trailing sparklies? or, what? Hard for me to know what you are talking about.
                            • cheebster
                              • May 2008
                              • 374
                              #194
                              Sorry for not being clear. It's hard to describe, it's like if the picture was working but the video was in 5fps instead of 5fps. it struggles on fast moving pictures and at the bottom i see a kind of doubling of the image
                              here's a video, you cant see the slow refresh since its a video of a video, but you see that doubling weirdo bug at the bottom of the screen a few times !
                              here's the video : http://www.youtube.com/watch?v=pKHUlenj3CE
                              if you watch it completely you'll see what i mean.. video is slow and buggy
                              thanks !!!!
                                Ah, I see it now.
                                I would suspect that you have a dodgy LVDS cable!
                                If it's not that I'd look at the buffers though it looks too "good" to be a buffer fault to me. Usually buffer fault causes sparkling random stuck pixels or pixel noise. Either way, it's not the Y-sus, Z-sus, or any of the drive voltages.
                                • cheebster
                                  • May 2008
                                  • 374
                                  #196
                                  it's the video input board that's giving me trouble. a swap with one from the other tv and results are good, using all the same cable. aaah another trouble again !
                                  i guess that one, you just replace it right ? i cant tell by checking the board what could be causing it.. ram chips maybe, idk. i see one xtal has been replaced already..
                                    If the xtal died the first time, maybe also the second time.
                                    You would need a scope to check though :/.
                                    • cheebster
                                      • May 2008
                                      • 374
                                      #198
                                      you're pushing me to buy one eh ? heehe just kidding...
                                      but what im wondering is, will i use it enough to justify that 400$ expense..
                                      is there a way to test an xtal ? // with a multimeter.. for now ?
                                      • cheebster
                                        • May 2008
                                        • 374
                                        #199
                                        anyone knows what causes a thin vertical line from to to bottom of display ? its very thin, about 1 pixel wide, and it doesnt appear on blacks only on colors. if i run an anamorphic movie with a black bar on top and bottom, the line isnt there.. its just on colors !
                                        could it be a flat cable on one buffer that needs some cleaning ? just thinking out loud.. its a very thin line, but its still annoying
                                        • cheebster
                                          • May 2008
                                          • 374
                                          #200
                                          I have another issue. Again.. from digging a little deeper in the old internets, ive found this interesting post.. on videokarma
                                          http://www.videokarma.org/showpost.p...9&postcount=14
                                          From what this guy says, its a good thing to check the YSUS at R61 (that's the testpoint) to check +18V on the ipm. And if it's off, it means trouble..
                                          Well mine is at 16.2 vdc right now. I don't have access to a remote (come from china, faster!!!) to get into the service menu and access that white wash, but for now, the voltage is off on the 18V on the ipm's.
                                          So something else is causing the death of the ipm's on that board, he says faulty caps, could be SMD... argh
                                          How is it possible to find leaky SMD caps if we don't know the value, since there's no service manual that cover component level for the y-sus ?
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
                                          • Burglicious
                                            Samsung PN59D6500 Plasma TV issues
                                            by Burglicious
                                            Hey all, i have a Samsung PN59D6500 that I rescued from the dumpster and I'm trying to fix it. So the issue I am having is that the TV isnt turning on at all. I have VS,VA,VSC,VE at all the appropriate voltages. I have 3.3V at the PS-On, and 5V also. Whats happening is when i press the power button on the remote the TV has has the relays click, some pixels flash on the screen and then it seems to turn off. It repeats this until the TV is unplugged. I know that the Mainboard has a problematic EEPROM but this seems kinda like a power regulation issue. Anyone have any ideas?
                                            12-09-2021, 09:03 PM
                                          • pixelcap
                                            Pioneer Kuro Pro 111FD 8 red blink error
                                            by pixelcap
                                            Pioneer Kuro Pro 111FD 8 blink red LED.
                                            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                            10-06-2024, 11:26 PM
                                          • SoulFreeze
                                            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                            by SoulFreeze
                                            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                            After repairing the above issue, I realized the following remaining problem,
                                            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                            The computer recognizes headphones are connected and displays a popup in windows
                                            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                            06-21-2025, 09:53 AM
                                          • Phlox321
                                            Samsung plasma tv PS43D450A2 pixel issues
                                            by Phlox321
                                            Hi guys. I have a Samsung plasma Tv with a wierd prpblem.its a samsung plasma PS43D450A2. A little history : I got the tv free from someone as the thought the power supply was bad and was about to throw it away. I check it and found shorted x main board. I found the diodes and igbts were shorted. After a long search for components i aquired them and replaced them. The tv then worked fine for a few months and about 2 weeks ago it started showing random yellow and purple pixels only on about the right of the tv. Its clearly cisible on a white screen but not as noticeable when watching a movie. And...
                                            04-12-2020, 03:58 AM
