LG Plasma 50PC1DR- Y-SUS Issues
    Re: LG Plasma 50PC1DR- Y-SUS Issues
    Shorted FET, or buffer board issues, or possibly the IPM (I'm not sure - there's no schematic diagram so I can't tell where the resistors connect to.)
    • cheebster
      • May 2008
      • 374
      Okay.. Well, i'm getting somewhere now. Tried to check the buffers, and i got a bad lower buffer on tv #1. Short as a nail
      Nothing new on the y-sus though.. I'm wondering, can i install sockets on y-sus and z-sus boards or the little added resistance would cause issues ?
      I got so many IPM's out it'd be QUITE handy to be able to troubleshoot them using sockets..
        You can try using them. It wouldn't be a good idea for a permanent solution though, as plasmas get very hot (especially the IPMs), and sockets have a tendency to expand and make intermittent contact.
        Regarding the buffers, you can try to power the buffer off 12V DC or so, the bad buffer chip will smoke, you can then remove that and the TV should fire up, of course with a black bar where the buffer chip is removed, but it will tell you if the Y-sustain is OK and all other boards are OK.
        • cheebster
          • May 2008
          • 374
          Okay, well i was right about the bad buffer on tv #1. I'm using a buffer from TV2 now on it, now what the tv does is start up, flashes on off and eventually shut down. No loud pop, all i see is the screen flashing from black to white.. trying to fire up and eventually giving up. Still suspecting one of the IPM's, but i don't even know which !
          I've seen so much information i don't even know anymore which failed ipm gives this symptom.
            Many TVs now don't like just one buffer removed due to the data being changed from one to another. So it doesn't surprise me that they go a little crazy.
            The IPMs only make the picture light up. If you have a lit up picture, they are pretty much guaranteed to be working.
            • cheebster
              • May 2008
              • 374
              #26
              Well i've used a good buffer from tv #2 on the tv #1 !! It's not missing a buffer, but still acting crazy (flashing picture on off, sound ok, then shut down after struggling to fire tv up).
              I really wish i was able to figure out if an ipm is good or bad !!!
              With that gummy stuff, it's really nearly impossible to tell, i've seen a bad one with the burned little square boards on the ipm... this one was clearly bad
              Anyone know a reliable way with a DMM test to know if a IPM is good ?
              I'm also wondering, if there's a way to know if a buffer is good other than the meter test on the y-sus connection pads. If a buffer has no shorts, one buffer chip (not a fet, but a buffer chip..) can still be bad, and meter won't tell, no ?
                Do you have a scope, or access to one?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #28
                  this seems a good training manual
                  • cheebster
                    • May 2008
                    • 374
                    #29
                    I don't have one, but that recycling center i got the plasmas for had one on the shelf there, 10$ and it's mine i guess. Seemed ok.. but i never used one.
                    I guess i might be able to understand how that thing works.. It'd be handy to really find out what's going on with the ipm's ? i'll grab it later today
                      You will also need a fixed 10X probe, with a 400V minimum rating. $10 would be an absolute bargain for one, are you sure it is in good working order? And no one else will have taken it?
                      • cheebster
                        • May 2008
                        • 374
                        #31
                        Not a lot of ppl know this place, it's small and fairly recent. I'll drop in later today see if i could pick it up. I'll google the model # before i buy Hey, 10$ is 10$ lol
                          Well, for comparison I paid (in GBP converted to USD) $100 for my 20 MHz one, and $400 for my 100 MHz digital one.
                          • cheebster
                            • May 2008
                            • 374
                            #33
                            At some point i was looking to buy one that was hackable.. i think it was made by Rigol. I'll look it up again.. Might be a good idea to buy one at this point
                            edit : http://www.ebay.com/itm/Rigol-Oscill...item3efb96a226
                            this is exactly the hackable one i was looking to buy. never used a scope before, though
                            • cheebster
                              • May 2008
                              • 374
                              #34
                              I bought some ipm's (yppd-j016's) to try on the boards. I see they are the ER ipm's and these seem to be the hardest working ones and more commonly failed than the J015's sustain ipm's, is that right ?
                              I also bought a hakko 808 desoldering gun which will make life really easier on the ipm removals. It seems like a great tool for anyone doing even a few reworks with multi pin ic's
                              • tw2005
                                • Oct 2011
                                • 6458
                                In the photos I see that next to those burnt R100 D35 & D36 are not populated. Is that the case still or are they the diodes you were replacing?
                                • cheebster
                                  • May 2008
                                  • 374
                                  #36
                                  hi tw2005 ! they are not populated, but i never removed anything from there, i think it's by design that they are missing.
                                  i was also wondering.. that waxy material that seems to be leaking from the orange caps, is that really coming from those caps that are leaking ? i've never seen such caps leak..
                                  I've noticed on 2 of the y-sus boards that waxy stuff from those caps. a lot of it..
                                  Need to replace the whole bank of caps ? Would be a good idea to do so ? So many questions.. well, i hope i'll someday be able to fix those plasmas
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    I'll be damned. I have 2 x 50PX5D sets and one has had a board swap and I have an "A" revision and a "B". You're right, not populated on the "B" rev.
                                    I can't see the waxy stuff. Are you talking about the Polyester caps?
                                    • cheebster
                                      • May 2008
                                      • 374
                                      #38
                                      yes ! those orange caps all in line. is it remotely possible that some of these leak waxy stuff ? of they don't even contain anything similar ?
                                      i have a fluke 115, i'm going to check if im able to check these caps with it... will report back
                                        They are just metal and poly insulator, they very rarely fail and when they do, they would be like a short circuit to the power supply, similar to IPM, but I have never seen them fail on LG's.
                                        • cheebster
                                          • May 2008
                                          • 374
                                          #40
                                          Ah ! So i can rule that out.. maybe that stuff is just something they've put between some caps to hold them there or something. I just got in with that Hakko 808, will pull out all the ipm's just for the heck of it right now.
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
                                          • Burglicious
                                            Samsung PN59D6500 Plasma TV issues
                                            by Burglicious
                                            Hey all, i have a Samsung PN59D6500 that I rescued from the dumpster and I'm trying to fix it. So the issue I am having is that the TV isnt turning on at all. I have VS,VA,VSC,VE at all the appropriate voltages. I have 3.3V at the PS-On, and 5V also. Whats happening is when i press the power button on the remote the TV has has the relays click, some pixels flash on the screen and then it seems to turn off. It repeats this until the TV is unplugged. I know that the Mainboard has a problematic EEPROM but this seems kinda like a power regulation issue. Anyone have any ideas?
                                            12-09-2021, 09:03 PM
                                          • pixelcap
                                            Pioneer Kuro Pro 111FD 8 red blink error
                                            by pixelcap
                                            Pioneer Kuro Pro 111FD 8 blink red LED.
                                            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                            10-06-2024, 11:26 PM
                                          • SoulFreeze
                                            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                            by SoulFreeze
                                            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                            After repairing the above issue, I realized the following remaining problem,
                                            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                            The computer recognizes headphones are connected and displays a popup in windows
                                            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                            06-21-2025, 09:53 AM
                                          • Phlox321
                                            Samsung plasma tv PS43D450A2 pixel issues
                                            by Phlox321
                                            Hi guys. I have a Samsung plasma Tv with a wierd prpblem.its a samsung plasma PS43D450A2. A little history : I got the tv free from someone as the thought the power supply was bad and was about to throw it away. I check it and found shorted x main board. I found the diodes and igbts were shorted. After a long search for components i aquired them and replaced them. The tv then worked fine for a few months and about 2 weeks ago it started showing random yellow and purple pixels only on about the right of the tv. Its clearly cisible on a white screen but not as noticeable when watching a movie. And...
                                            04-12-2020, 03:58 AM
