LG 42LG50 Works ... sometimes
  • drpj23
    • May 2012
    • 528
    Ok, so this LG (when it doesn't work) will power on but there will no be no backlight (i haven't been able to tell if there was still a picture since it hasn't failed again to let me do that). And it will do it off and on. Other times it works great.
    I have checked the other posts and most were having issues with the fuses but all checked ok even the black one.
    The only difference between that one was that the ON/OFF pin was only .84v instead of the 3.3 needed (except when working).
    Any ideas?
  • cadiman
    • Mar 2010
    • 397
    Re: LG 42LG50 Works ... sometimes
    I have not had any issues with this power supply. Looks like you have the good panel too.
    The Mainboard has been an issue with these sets.
    There should be a 24 volt feed to both inverters when powered on from the power supply.
    This is the last of the good L/G tvs.
    • drpj23
      • May 2012
      • 528
      Is there any way to be sure of the main board?....I honestly want to say inverters but have not a clue to be certain about it.
      Oh and there is 24v there. The only different voltage was that ON/OFF one so I can see why it could be the main board.
      Ok, unless i get any other advice, I may just shotgun it.
      • retiredcaps
        • Apr 2010
        • 9271
        1) The main board, which is hidden in your picture, generates the on/off signal.
        2) Check the voltage regulators on the main board (see my sig file below).
        3) Provide a clear focused picture of the main board.
        4) You may have bad caps on the main board.
        --- begin sig file ---
        --- end sig file ---
        • tibimakai
          • Jan 2012
          • 3680
          I have a 42LG70 which blows the fuses. I have replaced all the capacitors, since they were of low quality.
          I still couldn't fix it yet. Same exact power supply.
          It couldn't be a small startup capacitor causing this issue?
          • cadiman
            • Mar 2010
            • 397
            a 42lg70 is worth fixing.
            I have not had issues with this type (power supply). I would still replace any caps at stand-by part of supply.
            I have not had to troubleshoot these inverters.
            The mainboard issues I have had were not related to backlight control.
            • drpj23
              • May 2012
              • 528
              Well I just went ahead and ordered the main board so we'll see I guess and then go from there but thanks for the regulator tips though.
              • drpj23
                • May 2012
                • 528
                Well i just installed the main board, and now the voltages are:
                BRI - .49v
                ON/OFF- 3.3v
                PWM-DIM- 1.4v
                ERROR- 0v
                I do not see any backlight nor an image (but conditions might just not let me)
                Thoughts? Does 0v on error mean ...error?
                  Do you have the LCD panel make and model?
                  Is this "ERROR" pin at the inverter board or at the main board?
                  • drpj23
                    • May 2012
                    • 528
                    I can get that tuesday for you (the make and model) and at the inverter board.
                      The LCD panel spec sheet will give the information for the Inverter and the T-CON board pin outs and functions. It will tell you if the 0V on error pin is = good or not.
                      • drpj23
                        • May 2012
                        • 528
                        Although I have to give it back (i was working on it for someone) if it is relevant, V420H1-L12 is the panel.
                        • Anooc7
                          Samsung UN75NU6950 no backlight but leds works when checked individually!
                          by Anooc7
                          Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
                          09-16-2021, 06:16 PM
                        • CapLeaker
                          Dell ATX PSU won’t start, but forcing it works fine?
                          by CapLeaker
                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                          10-28-2024, 06:59 PM
                        • rounin
                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                          by rounin
                          🛠 Original Issue
                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                          04-19-2025, 01:18 AM
                        • ex250
                          Kenwood SW-505D no sound issue and pops from time to time when it works
                          by ex250
                          Hello mates,
                          I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                          It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                          12-29-2024, 03:27 PM
                        • eurowill
                          a2141 820-01700 internal display not working / external works
                          by eurowill
                          Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                          Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                          07-23-2024, 10:06 AM
