Vizo VW46LFHDTV10A want turn on
  • ronbass
    • Aug 2012
    • 10
    • US
    Hi guys my name is Ronnie and i have another vizio that want turn on. I do have amber light on front. I got this tv from girlfriend that had a lighting stri. I took back panel off and checked fuses and all were good no blown caps or no burnt spots on board. I had 5 vdc on ps board but no 12 or 24v. Now heres the wierd thing put ps board back in tv and it powered up about 4 times and stopped again. I need some help to lead me in the right direction troubleshooting this problem!
  • DakotaKid
    • Nov 2010
    • 165
    Re: Vizo VW46LFHDTV10A want turn on
    I have a VW46L with similar problem...I will follow along and help where possible and perhaps we can get both of our TVs up and running. I had put this one on the shelf while I worked on a couple of others so I will pull it out again. The first thing that will be asked for are pictures, 2000 x 2000 pixels or so that show plenty of detail and any observations of heat/damage/burn marks, etc. Also, any voltage readings or other tests that you have done to begin to narrow down the issue. Let's kick some tail on this one! I have a service manual but it doesn't include some important sections. It only has chapters 1-3 and 9. I need to check the site here and see if there is now a full cover to cover service manual download.
      Please post GOOD CLEAR AND FOCUSED pictures of both sides of the power supply board, closed up pictures of the connectors (power supply) so we can read the labels/markings. The whole back side of the TV so we can see how all the boards are connected together.
      Right now you may not have the PS_ON signal from the main board to turn on the main power supply sections.
      • awyatt2
        • Feb 2012
        • 407
        • america
        i have seen two of these in the 42" versions with bad solder joints at the power connector. dont know if they use the same psor not but might be worth a look to see if you have a bad connection on the back of the board where the pins go through.
        • ronbass
          • Aug 2012
          • 10
          • US
          OK I got to computer so i can post picturesso lets see if they are good enough from my mobile. I did not take any of the back because there were no burnt spots. Let me know if this is good enough. Thanks
          • Bafury
            • Jul 2012
            • 55
            ronbass & DakotaKid... I have available parts for your tv.. Let me know if you're interested. I have the power supply, master and slave inverter board, sound card, and remote. I do not have the main board
              Well, I cannot read any labels on the connectors of the power supply to see what the pins are, way out of focus.
              We are trying to troubleshoot the problem without having the boards in front of us, so good clear pictures are a must. I cannot help you much at this point since I cannot tell you where to test the voltages.
              • ronbass
                • Aug 2012
                • 10
                • US
                Here`s a couple pics of connector. Please let me know if you need anymore
                • selldoor
                  Slow Learner
                  • 7870
                  Pictures are not much better perhaps the second one will be clear enough for Budm
                  In the first one have you tested the fuses?
                  Have you checked the mains input pins as suggested by awyatt2
                  • ronbass
                    • Aug 2012
                    • 10
                    • US
                    yes the fuses are good and which connector would you be referring to with the mains
                    • selldoor
                      Slow Learner
                      • 7870
                      Mains electricity power connector. 120vac
                      • ronbass
                        • Aug 2012
                        • 10
                        • US
                        Yes Sir they are fine
                        • selldoor
                          Slow Learner
                          • 7870
                          Ok - In Pic 2 the end pin is marked on/off - with it all connected up can you plug it in but do not press power on and see if there is any voltage on that end pin. Set meter on 20vDC and put black probe on an earth screw and use the red to test on the pin. Actually you may as well do the whole connector list the results as:
                          Pin Name Actual
                          1 on/off 2.13v
                          2 12v 9.65v and so on.
                          Then do the test again after you press the power on button.
                          Then switch it off
                          You may need a helper for the next test. Again you have to measure pin one
                          same as before but hold the probes on the pin and ground and observe what happens when the power on is pressed.
                          • Rhetro
                            • Jul 2012
                            • 3
                            My compliments to SELLDOOR ! A excellent teacher with patients!
                            • ronbass
                              • Aug 2012
                              • 10
                              • US
                              Power off plugged in and power on the only ones that have any power are the
                              three 5v which measures 5.03v and the one that has dim .23v and inv had.002
                              pin 1 did not read any voltage switch it on. So where do we go from here.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Check your voltage regulators on the main board. See my sig file below on how to test and report the readings in the specified format.
                                --- begin sig file ---
                                --- end sig file ---
                                • ronbass
                                  • Aug 2012
                                  • 10
                                  • US
                                  One quick question pwr switch on or off
                                    On, and in the "failed to start" mode.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Please can you update your profle with mains voltage and country.
                                      • ronbass
                                        • Aug 2012
                                        • 10
                                        • US
                                        U2 u6
                                        4558 line 1 4558 line 1
                                        h455a line 2 h455a line 2
                                        1 0 5 .03 only pin 6 had voltage of .5-1.6
                                        2 .06 6 .03
                                        3 .16 7 5.58
                                        4 5.6 8 0
                                        u14
                                        4953gm line 1
                                        h4558 line2
                                        1 .31 5 4.99
                                        2 .31 6 4.85
                                        3 .31 7 4.99
                                        4 .31 8 4.85
                                        u15
                                        1084 line1
                                        0740al line2
                                        vi .32
                                        vo .30
                                        u17
                                        j483 line 1
                                        g1117 line2
                                        1 .48
                                        2 .78
                                        3 .31
                                        u19
                                        1084 line1
                                        0740al line2
                                        vi .32
                                        vo 0
                                        u20
                                        1084 line1
                                        0740al line2
                                        vi .22
                                        vo 0
                                        u21
                                        j483 line 1
                                        g1117 line2
                                        1
                                        2 .34
                                        3
                                        u31
                                        atmlh750 line 1
                                        02b 1 line2
                                        1 4.75
                                        2 .06
                                        3 4.45
                                        4 4.45
                                        u32
                                        atmlh750 line 1
                                        02b 1 line2
                                        1
                                        2 .06
                                        3 .30
                                        4 .30
                                        u33
                                        atmlh750 line 1
                                        02b 1 line2
                                        1 4.74
                                        2 .06
                                        3 4.70
                                        4 4.70
                                        u34
                                        atmlh750 line 1
                                        02b 1 line2
                                        1 4.73
                                        2 .06
                                        3 4.71
                                        4 4.71
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • brzostos
                                          HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                                          by brzostos
                                          Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                                          After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                                          Original HP 150W power supply, the diode in the power socket lights...
                                          10-01-2024, 01:34 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
