Vizio tv black screen & amber light
  • Acoustic101
    • Aug 2012
    • 17
    • Usa
    Happened randomly when I turned on the tv one day. Not real experienced in tv repairs but would like to know what's wrong with it and save some money.
    Model: VOJ320F1A
  • Mike Jenk
    • Jul 2012
    • 113
    Re: Vizio tv black screen & amber light
    Well, first you’re going to want to read the beginners post where you will find some really good fundamental things, on how to test some components once you open it up and then also read about how to post your pics of the boards inside. I am way to new to help other then with that simple stuff and that I am in the process of fixing a Vizio with bad caps on it and it all came from the folks on this forum. Good luck.
    • Acoustic101
      • Aug 2012
      • 17
      • Usa
      Will look at now , thanks.
      • Acoustic101
        • Aug 2012
        • 17
        • Usa
        Wheres that post at btw?
        • Mike Jenk
          • Jul 2012
          • 113
          Search, Inserting Images in your post
          • Acoustic101
            • Aug 2012
            • 17
            • Usa
            Ok, now I'm still not skilled in what boards to take pics of and which ones to look at but that's up to whoever can assist me further. Thanks for the info man
            • Mr Bill
              • Nov 2011
              • 648
              We are going to need the entire story of what the tv is doing. Vizio light goes from standby (amber) to ON (white) but shows nothing, or turns back off, freezes. ect ect ect....... Be as specific as possible.
              As far as pictures, Get atleast one of the power supply, main board, and one of the entire back of the set.
              • Acoustic101
                • Aug 2012
                • 17
                • Usa
                I turn the tv on and the light stays amber with a black screen but I can hear it running on the inside but otherwise no audio. Could you tell me where these boards are? All I have is the back case off
                • Mr Bill
                  • Nov 2011
                  • 648
                  Post a picture of the entire back of the tv with the cover off and then we can help identifying the seperate boards.
                  So the tv basically won't turn on at all. Does the vizio logo change to white quickly then back to orange?
                  • Acoustic101
                    • Aug 2012
                    • 17
                    • Usa
                    Negative, just orange
                    Http://s756.photobucket.com/albums/x...nt=image-1.jpg
                    • Mr Bill
                      • Nov 2011
                      • 648
                      The exposed board on the back is the power supply. The main board is below the power supply under the metal cover. Can you get a sharper photo of just the power supply. If you can get a clearer photo use the manage attachments (paper clip). Get the photo as close to 2000 x 2000. I use paintbrush to shrink my pictures down.
                      • Acoustic101
                        • Aug 2012
                        • 17
                        • Usa
                        On a phone, best I can do is provide the link . Sorry. http://s756.photobucket.com/albums/x...%3Dimage-2.jpg
                        • Acoustic101
                          • Aug 2012
                          • 17
                          • Usa
                          Anything?
                          • Wrog
                            • Oct 2009
                            • 472
                            With all due respect, you'll need to provide more info and better pictures if you want to receive additional help. Once the TV is on, does the remote still work (in particular, can you turn it off without unplugging it)? Can you change inputs? Can you use a flashlight and see any faint images? Have you searched the other threads in this forum for common Vizio problems?
                            • Acoustic101
                              • Aug 2012
                              • 17
                              • Usa
                              I have checked every other thread but no definitive answer
                              • Wrog
                                • Oct 2009
                                • 472
                                Excellent! Then you are already aware that the more detailed information you provide, as well as quality of pictures, the more help you will get. While you are gathering that information, if you could answer what I've asked someone can point you in the right direction in the meantime.
                                  Well, you have 4 major boards in this TV that can cause the problem you are having.
                                  Power supply board: right now the standby power supply is working but the rest (12V, 24V, main 5V) may not be working due to not getting the signal from the main board to turn them on. Or those section of the power supply is bad due to bad caps, bad connections, etc. Or it senses short circuits so it stays in shutdown mode.
                                  Main Board: bad main board not working due to bad regulators, processor, bad solder joints so it does not send the signal to turn on the power supply, T-CON board, inverter board.
                                  Backlights inverter boards: it has shorted circuits due to MOSFET's, IC, Transformers, bad connections, bad lamps assemblies, etc. so it causes the power supply to go into shutdown, or sends an error signal to the main board to tell the TV to stay in shutdown mode.
                                  T-CON; blown fuse due to short circuits, failed IC, bad connections, so it sends the error signal to the main board to shutdown.
                                  As you can see, we are trying to troubleshoot the problems without having the TV or the boards in front of us the look at. Good pictures are the only things we have to go by and it can be real hard to do by just looking at the pictures of both sides of the boards and try to trace out the connections on the boards to locate the problems and to provide the test points for you to look at and check the voltages.
                                  It is not that simple.
                                  • Acoustic101
                                    • Aug 2012
                                    • 17
                                    • Usa
                                    Sorry for late response but I have been busy. Tell me what to do and what to take pictures of and I can handle it. Currently I have only taken the back cover off so walk me through from there if you will.
                                      Take the pirtures that will show how all the boards are hooked up together, then individual pictures of the top side of the boards for now.
                                      • Acoustic101
                                        • Aug 2012
                                        • 17
                                        • Usa
                                        What I am looking at, what needs closer pics again?
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • Ihandyrepair
                                          sony 55X850D black screen no front white or red led light.
                                          by Ihandyrepair
                                          Hi guys
                                          strange one
                                          I have a dead Sony 55X850D
                                          when plug in, black screen, no front white or red LED, no back light no screen
                                          Voltages I get
                                          3.3v LD/power and main board
                                          reg 12V
                                          reg 19V
                                          3.3v on power on pin
                                          no Tcon on
                                          no tcon 12v
                                          no BL_on
                                          I do get BL_ERR 2.0v
                                          I tried to bypass it by ground it but still get same symptom
                                          I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                          or is possible the chip next to...
                                          08-07-2024, 04:58 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • paqman
                                          Vizio M60-C3 black screen
                                          by paqman
                                          So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                                          So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                                          03-02-2024, 04:37 PM
