Hi guys,
having trouble trying to figure out an issue with a Bush 24" LCD TV. The issue is it will not turn on at all. When plugged in there is no 12V output from the power board/Inverter. It's a Delta DPS-83AP. I'm familiar with electronics but a novice when it comes to debugging down to component level. Tools I have for testing are a Fluke 179, Atlas ESR60, soldering iron and cheapo analogue meter. Anyway, as well as measuring resistors and caps this what I've done so far:
On primary side.
Measured 230VAC coming to board
Measured 230VAC on the rectifier
Measured 300VDC at filter cap C101.
Measured 9V at VDD of IC101 (SG6742MRSY). Not sure if this is correct as I suspect it should be 12V-16V. If so, what should I be doing next?
On the secondary side
Tested the dual diodes (CR151 is FCH20A10 & CR152 is SBR10150C TF) for DC on the secondary by placing red probe to the common cathode and black probe to ground but not getting anything and I think I should be getting 12V? Perhaps I'm doing it wrong? Also, tested them using for bias & seem ok, ie 197OHMS in one direction & OL with probes reversed.
As I said my knowledge is limited so I'm hoping one of you guys here would be able to point me in the right direction as to what to do next. Pics of both boards attached.
Cheers!
On primary side.
Cheers!
