Bush LCD TV no power *HELP!*
    Re: Bush LCD TV no power *HELP!*
    Originally posted by beemerbruser View Post
    Examined the board again & found a small crack on one of the tracks in the primary side, so rubbed it down to expose copper & joined with a bit of solder. Plugged mains back in & it powered up!
    Good job. Like I said, most people would have not have solved the problem.
    So any recommendations for a broken track?
    https://www.badcaps.net/forum/showpo...8&postcount=12
    http://www.circuitrework.com/guides/6-1.shtml
    --- begin sig file ---
    --- end sig file ---
      @retiredcaps - Attached is more cap pics, C103 & C113. Hopefully these are the ones you are referring to.
      C103: 10uF 50V - Readings: 9.32uF, ESR: 0.50
      C113: 33uF 50V - Readings: 36.66uF, ESR: 0.06
      I didn't bother looking up the datasheets for the above because I saw Rubycon and UCC KY caps. Both are excellent series caps and rarely go bad.
        Originally posted by selldoor View Post
        @retired caps - good to have you back keeping me in order now the olympics is finished.
        Completely OFF TOPIC, but now that the OP's TV is fixed ...
        With summer winding down, I'm trying to take advantage of what is left of it so badcaps.net is low on the priority list.
        BTW, congrats to the UK for an excellent performance at the Olympics. It is good to see the home country do well.
          Glad to see you fixed it and it would have taken me quite some time to find that, if I had found it at all!
            So any recommendations for a broken track? A bit of solder joint enough or would a bit of resistor wire be better for the job?
            Thanks again folks!
            Yes - well done- might depend where it is how big the gap it and whether you use leaded or unleaded solder - to be absolutely sure for long term, use a piece of wire.
              Thanks again for help guys.
              How I found it was to go into a dark room hold board over a bright light while examining it so you can nearly see through it.
