Bush LCD TV no power *HELP!*
  • beemerbruser
    • Aug 2012
    • 13
    • Ireland
    Hi guys,
    having trouble trying to figure out an issue with a Bush 24" LCD TV. The issue is it will not turn on at all. When plugged in there is no 12V output from the power board/Inverter. It's a Delta DPS-83AP. I'm familiar with electronics but a novice when it comes to debugging down to component level. Tools I have for testing are a Fluke 179, Atlas ESR60, soldering iron and cheapo analogue meter. Anyway, as well as measuring resistors and caps this what I've done so far:
    On primary side.
    Measured 230VAC coming to board
    Measured 230VAC on the rectifier
    Measured 300VDC at filter cap C101.
    Measured 9V at VDD of IC101 (SG6742MRSY). Not sure if this is correct as I suspect it should be 12V-16V. If so, what should I be doing next?
    On the secondary side
    Tested the dual diodes (CR151 is FCH20A10 & CR152 is SBR10150C TF) for DC on the secondary by placing red probe to the common cathode and black probe to ground but not getting anything and I think I should be getting 12V? Perhaps I'm doing it wrong? Also, tested them using for bias & seem ok, ie 197OHMS in one direction & OL with probes reversed.
    As I said my knowledge is limited so I'm hoping one of you guys here would be able to point me in the right direction as to what to do next. Pics of both boards attached.
    Cheers!
  • selldoor
    Slow Learner
    • 7870
    Re: Bush LCD TV no power *HELP!*
    Voltage at Big cap is too low - should be around 325 vdc - all your dc voltages are low
    is your meter ok - check battery.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by beemerbruser
      On primary side.
      You are correct in your assumption that the voltage of IC101 VDD should be around 12-16V.
      The datasheet says
      15.5V is typical with a range of 14.5 to 16.5.
      My spatial mapping skills are weak at best, but underneath that top right hand corner heat shield might be an electrolytic cap in the 47uF 50V range that is your startup cap. It might be bad without visible signs of bloating. Since those caps are only around 33 cents, I would replace it first to rule out a bad cap. Use something like Panasonic FC series.
      Since you are also in Europe, you might/probably have PFC circuitry involved which would boost the DC voltage across the big cap to around 400VDC.
      Your post is easily 98% better than most of the posts asking for help.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        The Fluke 170 series (175, 177 and 179) will have a low battery icon indicator, but will still be accurate. When the battery is below a certain threshold, it will then display "batt" and not take any more measurements.
        Refer to
        https://www.badcaps.net/forum/showpo...2&postcount=21
          I have an el-cheapo DMM at work (some Mastech brand.) Low battery icon comes on, display gets very dim (invisible looking straight on), but if you look at an angle, reads exactly the same (+/-1 digit) as the Fluke 179 which I use for proper stuff.
          It is very surprising to see a high quality Delta PSU, with good Chemicon and Rubycon caps, in a Bush. Is this LED backlit? Bush TVs, in my experience, are built down to a very low price. The Bush brand is owned by Home Retail Group, i.e. Argos. Despite the low build costs, they are usually only £10-15 cheaper than comparable Samsung TVs (which are okay, if you replace the caps.)
          • beemerbruser
            • Aug 2012
            • 13
            • Ireland
            Hi, thanks for quick post.
            I was always under the impression that around 300V DC was normal on the big cap. Regardless I've replaced battery & now reading 308VDC. However, this has no bearing on actual fault so any ideas what next? Because I'm not seeing anything on the secondary diodes I assumed there is an issue somewhere on the primary side. The transformer details if this is helps are
            MD-1301 (00)
            MV-DP9569 DELTA
            DCUM1002(02) 2D3
            Cheers
              Check your mains line voltage - one probe in live and one in neutral - if 308V you should have line of = 217V. Minimum in UK&ROI is 216VAC (max 253VAC).
              Call your electric company if it's that low as it's not good!
              • selldoor
                Slow Learner
                • 7870
                @retired caps - good to have you back keeping me in order now the olympics is finished. Id watch the video but its 16 mins and my son is currently "skyping" his girlfriend in Canada of all places so at the bit of bandwidth I can get I reckon it will take a couple of hours so I'll just take your word for it..
                @ BB Something is not right what voltage do you get on the~~ pins on the bridge rectifier. Also can you quote voltages to two places 300.01 12.02 etc.
                All yours end in 00?
                EDIT
                Sorry you say 230vac at the bridge - what do you get at the + & -
                • beemerbruser
                  • Aug 2012
                  • 13
                  • Ireland
                  Firstly, thanks guys for the rapid responses!
                  @retired caps - see attached pic of under heatshield. Looks like it says "RR 222K 1KV" printed on it . According to the ESR meter it's 0.26ohms. Does this sound ok or should I remove & test ooc or just replace regardless?
                  @tom66 no it's an LCD 1080p & yes I was surprised too by the quality of components used. If only it would work though! Line voltage is ok 223.8V
                  @selldoor 311.6V at the + & -
                    223.8V * 1.414 = 316V. About right then. You just have low line voltage in Ireland. Here I am getting a good 245V (varies by about +/-2V over the day) and at my dad's place (off the beaten track a little) I get 252V almost continuously.
                    Can you post a pic of the power connector going to main board - of interest is the labels near it.
                    • selldoor
                      Slow Learner
                      • 7870
                      I dont think he meant that one - unless I have missed something - its a small electrolytic - perhaps its the one at C103
                      • selldoor
                        Slow Learner
                        • 7870
                        Just been looking at the bottom of the board maybe just the picture but a lot of the joints look a bit ringed. Perhaps resolder all the transformer joints?.
                          Pretty typical for Delta soldering to be excellent; the rings are support rings added for big heavy components, very nice touch to ensure long term reliability.
                          • beemerbruser
                            • Aug 2012
                            • 13
                            • Ireland
                            @retiredcaps - Attached is more cap pics, C103 & C113. Hopefully these are the ones you are referring to.
                            C103: 10uF 50V - Readings: 9.32uF, ESR: 0.50
                            C113: 33uF 50V - Readings: 36.66uF, ESR: 0.06
                            @tom66 - Attached pics as requested.
                            Anymore info needed let me know.
                            Cheers guys!
                              OK, do you get good 12V at the pin marked 12V? Looks like this PSU only has a single 12V output and no standby mode, pretty typical for a small 24".
                              • beemerbruser
                                • Aug 2012
                                • 13
                                • Ireland
                                I get nothing. That's my problem. Sorry, I should have clarified that at the start.
                                  That's where the fault must be then. But, if the startup cap were an issue, you would get low, unstable outputs, not zero outputs. Check the rectifying diodes for the output side - one may be shorted.
                                  • beemerbruser
                                    • Aug 2012
                                    • 13
                                    • Ireland
                                    Can you read through my 1st post & see if I've done it right already or are you talking about something else? It's been 15 years since I was in collage doing this stuff
                                    As Retiredcaps has said earlier, I should be getting more than 9V at VDD of IC101. If don't have this then there's hardly any point in trying to take measurements in the secondary.
                                      The way a modern SMPS works is to provide a little low current through a high value resistor (330k to 2Meg) to charge up a small cap (10..100uF 16-50V) regulated by a zener diode (sometimes integrated into the IC.) As the voltage reaches a certain point, the switching converter suddenly starts (normally it is using almost no power.) This drains the cap, but the idea is the converter has enough energy in the cap to keep going until the tertiary winding of the power supply (like an additional output) can supply power. The converter has to run for at least 50-100ms so the capacitor must have good capacitance (ESR isn't as crucial for it but still plays a role.) Also, the tertiary power is usually supplied through a low value resistor (1 ohm to 47 ohms) and a diode (1N4148 typically.)
                                      If you have a shorted diode on the secondary, the tertiary winding will get no power, so the converter will never start.
                                      Sort of like a car will start with a dead alternator and charged battery, but won't run for long.
                                      • beemerbruser
                                        • Aug 2012
                                        • 13
                                        • Ireland
                                        Ok guys bit of an update. Examined the board again & found a small crack on one of the tracks in the primary side, so rubbed it down to expose copper & joined with a bit of solder. Plugged mains back in & it powered up!
                                        So any recommendations for a broken track? A bit of solder joint enough or would a bit of resistor wire be better for the job?
                                        Thanks again folks!
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
                                        • tyler123456
                                          Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                                          by tyler123456
                                          Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                                          I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                                          I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                                          Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                                          Anyone...
                                          08-16-2024, 12:51 PM
                                        • modtool
                                          Sony PS4 slim CUH-2216A power supply ADP-160FR not working after short in PFC
                                          by modtool
                                          Dear forum members,
                                          I'm working on this power supply for ps4 slim, that behaves in a similar manner as other cases but I can't find a way to solve the problem.
                                          When it came to me, externally the ps4 had standby voltage, clicking the disc eject button made the triple beep (without disc inside) and cliking on the power button made the blue power light turn on and then all turned off within 1 second.
                                          When I opened it up, I found these components shorted:
                                          Q6 24N60M2
                                          IC41 1612A (not really shorted but had a hole on it and all pins measured open circuit but the 9th...
                                          05-31-2023, 08:09 AM
                                        • Johnny.p
                                          Bush WI-1810 Internet Radio
                                          by Johnny.p
                                          I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
                                          U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
                                          11-25-2023, 04:18 AM
                                        • Simplebeans
                                          Macbook Pro A1989 820-00850-a not powering on
                                          by Simplebeans
                                          Hey guys i just got myself a Macbook Pro A1989 820-00850-a 2018, the seller said they had spilt liquid over it and since then it has never turned on.
                                          I am using a Apple 61W USB-C Power Adapter and USB-C Charge Cable and on my USB tester i can see when i plug into the power i get around 5.21V and stays at 0.24amps. I am currently testing disconnected from the battery and only plugged into the USB-C Charge Cable.
                                          When opening the machine I was greeted with corrosion on, in and around, in particular the U3100 (USB-C PORT CONTROLLER XA) and U3200 (USB-C PORT CONTROLLER XB)...
                                          03-26-2022, 01:56 PM
