Insignia NS-LCD42HD-09 screen problems
  • ntehicks
    • Mar 2011
    • 272
    I have an insignia 42" lcd tv that has an issue with the picture. half of it looks like a T-Con and the other half looks like a bad panel. what kind of tests can i perform to see if it is the panel.
    http://www.youtube.com/watch?v=NbqDwlVZQAc
    here is a video of what the TV is doing
  • selldoor
    Slow Learner
    • 7870
    Re: Insignia NS-LCD42HD-09 screen problems
    Have you tried disconnecting cleaning and reconnecting ALL removable cables including the Tcon to panel flat cables. Try a new cable - dry and crack with heat.
    Please can you update your profile with Country and mains voltage.
    • ntehicks
      • Mar 2011
      • 272
      Update on TV repair
      http://www.youtube.com/watch?v=g_XpFmPGpRQ
      this video shows what trouble I was having with the TV then I checked out the Tabs on the Top of the LCD Panel. I pressed on the very far right and left tabs and the screen went normal. I put some foam on both sides and tested. The TV is working great.
      • zbabyface
        • Apr 2013
        What tabs are we talking about? I have the same problem... TV has verticle lines on just the right side of the TV until it warms up or I hit the back just right....lol
          See example here:
          https://www.badcaps.net/forum/showthread.php?t=25371
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • jean luc ferre
            display screen problems after changing motherboard
            by jean luc ferre
            First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
            I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
            Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
            Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
            09-11-2025, 10:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • valvashon
            LG 55UH6150- trouble powering up, then half lit screen (pictures!)
            by valvashon
            The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
            Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
            11-24-2024, 12:08 PM
