Insignia NS-LCD42HD-09 screen problems
  • jean luc ferre
    laptop hp g72 b52sf screen problems
    by jean luc ferre
    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
    i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
    06-07-2025, 03:27 PM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • valvashon
    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
    by valvashon
    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
    11-24-2024, 12:08 PM
  • Raulnn
    TD Systems K50DLG12US half black and half white screen
    by Raulnn
    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
    01-20-2024, 04:49 PM
