Re: Neon C3298DVB stuck in standby
now you have the eeprom fitted press Source> 2580 then scroll to 'RESET ALL,that should do it,if it dosent then there is another problem
Hi tom..eeprom fitted right way..i fitted it from the dot on chip 2 pin 1 which had an arrow on board aswell..also drew a picture to defo make sure..ive unplugged all connection to main board fron psu aswell as testing them plugged in..its weird as all the voltages where present at 1stLeave a comment:
Check EEPROM is fitted right way around.Leave a comment:
Is the 47uf 50v normally the start up cap?..theres 3 of those but i dont know which 1 is the start up cap.Last edited by sienoki; 08-13-2012, 07:48 AM.Leave a comment:
yes,i had and still have the same problem,i did take off the chip easy enough and re solderd back on,the trick is to use plenty of flux and a decent hot iron,though after i removed it,i realised the chip can be re-programmed on board with a special clip.
i have the ezp2010v.2.1 programmer and i had the firmware to put on it,but as tom said if it was eeprom then it be easy to do,but these chips are spi flash,and more than likely need a more expensive programmer,i tried but it didnt work.but that was on the original chip not a new chip.it may work with new chip.
my board if i remember is a cv1o6ls1 v2.1 and it is always the flash chip that goes.
id be inclined to get the pre-programmed chip and take a chance seeing as its a 32",mine is still stuck on my bench ,il get the chip as and when i come across one,im in no rush.Leave a comment:
Ive found 2 sites that suggest source 2580 but no joy..looks like a new chip & then programming so stuck with this 1 for a while
This programmer looks 2 do the job Item number: 110771573141 on ebay..
Multimeter i see you had the same chip at 1 point on another thread..did you ever get it sussed..thx.
Ive come across this site in the.. http://www.ohmsupplies.co.uk & was wondering if any of you guys have ordered from them before?..They have the chip in stock & pre-programmed with delivery at 16quid.
If alls good with this site how easy is it 2 remove the chip..can it be done with a soldering iron & desoldering braid..thx..also is there owt else i need 2 know or is it just replace the chip..thx
It's easy to remove with experience, but I wouldn't recommend trying the first time on a board that's hard to get hold of.Leave a comment:
If alls good with this site how easy is it 2 remove the chip..can it be done with a soldering iron & desoldering braid..thx..also is there owt else i need 2 know or is it just replace the chip..thxLeave a comment:
Multimeter i see you had the same chip at 1 point on another thread..did you ever get it sussed..thxLast edited by sienoki; 08-09-2012, 04:57 PM.Leave a comment:
If it's one of those, I can't program it, sorry. That's a flash chip - not an EEPROM.Leave a comment:
im sure there is a service code but i dont know that one sorry,someone may pick up on this thread and chime in hopefully.Leave a comment:
When you going 2 uni fella?..where will i get 1 of these chips from?..& could you program it 4 me..thxLeave a comment:
no,you done it right,on these eeproms there storage is very weak,any little power outage/surge will corrupt the eeprom,it will proberly be a case of re/writing the eeprom,you can get the blank 24c/25c winbond eeproms fairly easily,they normally have SIG written on there part number.Leave a comment:
and one thing,some watch screwdrivers have a black coating on them,make sure that you use one with a clean bare metal blade or it wont make the correct contact with pins 5/6Leave a comment:
Thx multimeter..located the 2 pins put small flat srewdriver on both & switched on at switch at the side waited 2secs & still same..is this a matter of trying longer or this cant be done..thxLeave a comment:
by lepak06Hello
I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
The TV is faulty with stuck in Standby RED LED. Can't power the TV.
Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power... -
by toty79Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
As per Hisense tv title LTDN50K220WSEU stuck in standby
PSU rsag.820.5687 HLL 4855WF
Main rsag 7.820.5842
I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages... -
by lego1234567Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
What could be the problem ? Thanks...2 Photos01-21-2024, 03:39 AM -
by RusengaHi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
Connector CNM803:
TV ON
Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
TV OFF
Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...09-18-2021, 11:51 AM -
by UkdiggerWhen the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
PSU number bn44-00610A L46SF_dpn
1 B13v 12.4
3 B13v 12.4
5 Vamp 12.4
7 Vamp 12.4
9 GND... - Loading...
