Toshiba TV not powering on?
  • Senatov
    • Aug 2012
    • 51
    Hello!
    I have a 7 year old Toshiba HDTV. It has worked fine all these years, and today it stopped working. I went to turn it on, and I noticed that the red light that comes on when the TV is off was on like it should be. I went to turn on the TV, and nothing happened. I pressed power again, and now the red light went out, and the backlight came on for a few seconds, then went off. I unplugged the TV, and plugged it back in. Now there is no power what-so-ever. When I press power, I hear a 2 clicks, but nothing else happens. When I press it again, I hear 1 more click, but neither the screen nor the red status light come on at all. I tried unplugging the "PJ63" inside the TV that I heard about on another thread. This did nothing. If I have to get this repaired professionally by a person, I will just buy a new TV. The thing that concerns me, is not even the red light comes on. What could be wrong with it? Thanks.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Toshiba TV not powering on?
    Power supply could be dead.
    Muh-soggy-knee
    • Senatov
      • Aug 2012
      • 51
      How likely is this to happen? Does the clicking sound signify this?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        The clicking sound is a relay you hear in the power supply.
        However the PSU might not be bad, it could be shutting down due to something that is shorted out on another circuitboard.
        Some pictures would be helpful
        EDIT: Also, you didn't even tell us what model it is!
        Muh-soggy-knee
        • Senatov
          • Aug 2012
          • 51
          Sorry. I think I will just buy a new TV. They're pretty cheap nowadays.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Aw ok
            Muh-soggy-knee
            • Senatov
              • Aug 2012
              • 51
              I changed my mind. I might as well try to fix it. It is a Toshiba 32HLX95. It is 32 inches and it is 7 years old. Here are some pictures:
              Inside the TV
              The PJ63 up close.
              Let me know if you need more info or pictures.
              • Senatov
                • Aug 2012
                • 51
                The more I think about it, this is seeming more and more like a PSU issue.
                • selldoor
                  Slow Learner
                  • 7870
                  You had better post pictures of the power supply then.
                  We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                  Examples of what is needed
                  https://www.badcaps.net/forum/attach...1&d=1290283049
                  https://www.badcaps.net/forum/attach...7&d=1280167246
                  It will be useful if you can say a bit about yourself - skills tools etc.
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    sounds like a classic bad caps issue,close up of the psu?,do you have a esr meter and multimeter?
                    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                      Does this TV have two HDMI? I had a Toshiba with a similar symptom, was a bad switching regulator on the video process board.
                      • Senatov
                        • Aug 2012
                        • 51
                        No it only has 1 HDMI.
                        • Senatov
                          • Aug 2012
                          • 51
                          Here is the PSU:
                          https://www.badcaps.net/forum/attach...1&d=1344270805
                          I only have a screwdriver, but I can get some more tools if I need to.
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            you will need a multimeter,no sign of visualy bad caps,check you have standby voltage with tv just plugged in,then check the on/off signal goes high when switched on by remote/side buttons,could do with nice sharp pic of the all the connectors to see what the legends say,hard to tell from that picture
                            • selldoor
                              Slow Learner
                              • 7870
                              Pictures are a little too grainy for troubleshooting - we need to be able to read
                              the writing on the board. Not sure what this board is? more like power distribution - can you do the one with the mains connector on it.
                              • randtek
                                • Oct 2011
                                • 280
                                • US
                                The above picture is not the power board. It is the "Sub Power" board. The board we need to see is to the right of this one, is green and mounted vertically. It is the tall board just to the left of the DVD deck. (When viewing from the back of the TV)
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  yup wrong board! ^^^,im to tired!
                                  • Senatov
                                    • Aug 2012
                                    • 51
                                    Ok, sorry. I am currently trying to take some pictures with my better camera. It is difficulty to get the whole the board in 1 picture and not lose detail. Hold on.
                                    • Senatov
                                      • Aug 2012
                                      • 51
                                      Here are some high-quality images.
                                      Sub-Power Board: https://www.badcaps.net/forum/attach...1&d=1344273971
                                      Also, my neighbor repairs appliances, unfortunately not TVs, but he just came home for lunch, and I asked him if had a multimeter. Luckily he did, and he offered to test the caps for me. He tested all the caps on those 2 boards, and he said they are all working fine, so I will take his word for it.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Ok, try measuring the voltage on the really big capacitor in the power supply. It should be about 300v DC, if its only about 160v, press the power button and see if it goes up to 300v before it goes into protection mode.
                                        Muh-soggy-knee
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
