Hitachi LCD low squeal from speakers
  • DoctorWedgeworth
    • Jul 2012
    • 65
    • England
    I had one of these that wouldn't turn on, turned out to be 5 blown caps on the PSU. I replaced them, and it works, but now when it's on a no input screen, or another silent screen, it emits a low volume squeal. It's possible it does this all the time, but it's not noticeable when there's sound playing.
    It goes off if I hit mute, and I never saw this TV on before I replaced the caps. Someone suggested I might have shorted it slightly when replacing a cap, and the speaker is transmitting this as noise. Is that possible?
    It's not a big deal and I don't want to have to spend anything to fix it (except maybe a couple of quid on components), but if it's an easy fix I'm all for opening it up again.
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Hitachi LCD low squeal from speakers
    check power board grounding points,could be picking up oscillations from smps transformer,did you use decent branded caps to replace?,i.e checking the esr,ripple is higher or equal?rubycon,panasonic?
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • DoctorWedgeworth
      • Jul 2012
      • 65
      • England
      I used the cheapest caps I could find (from eBay) and only thought to check the numbers not the brand. I know that might sound like sacrilege here but it was before I discovered this forum.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        you need to check what the blown caps caps were,the impedence,the ripple current,the voltage,and stay the same or EXCEED the specs,if you used caps that were a higher impedence (esr) the power supply will be struggling to push power through to its respective rails,in your case the rail that supplys power to the audio side of the mainboard,eventually the psu will fail ,if the caps are not correct,then this possibly could alter the output rail voltage,as a rule,i always use panasonic fm in every power supply i repair,and never had any problems whatsover,at the moment im looking for a scope to check power supplys,to make sure there is minimum output ripple from the rails,at the moment i use a dmm to make sure the output voltages are within spec of what they should be,if you have one then check voltages are correct,a low voltage somewhere could underpower the amp circuit and cause speaker noise.
        • DoctorWedgeworth
          • Jul 2012
          • 65
          • England
          Thanks for the advice. I threw the old capacitors away, only made a note of the u and the voltage. Guess this is a learning curve
          I might see if I can find an instruction manual for this TV online to find out what they should be and/or what the voltages should be. I do have a DMM, although I'm not sure how good it is.
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            try here http://elektrotanya.com/
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              trouble is if you do find a schematic diagram,it wont state the brand and series of the capacitor,only the uf and voltage,if you knew the old brand and series,you can look up the datasheet ,and compare results
                Is the chassis made by Vestel? I have had several Vestel TVs using the same particular audio circuit, and they all make a low squeal - they are rubbish!
                • DoctorWedgeworth
                  • Jul 2012
                  • 65
                  • England
                  It's a Hitachi 32LD6600B. There's no mention of Vestel on the label.
                  You seem to follow me around telling me my TVs are rubbish
                    Yours is a Vestel. This is the audio board. http://flattvparts.co.uk/bmz_cache/5...ge.400x305.jpg
                    It *may* help to replace those capacitors on it but I couldn't guarantee it.
                    Sorry, but I have opened up too many and have too many opinions . When you repair a Sharp, Sony, Panasonic or Toshiba you start seeing quality. (Except the newer Sharp and Toshiba TVs which are just Vestels!)
                    I will say this simply: Vestel the worst, most unreliable TVs ever. They are built using bottom of the barrel components and they are very poorly laid out. And now, you see brands like "Finlux" who are just rebadging Vestel TVs. No "happy Finnish" when it dies in 14 months time.
                    • DoctorWedgeworth
                      • Jul 2012
                      • 65
                      • England
                      Do you think it's worth bothering? If the TV was likely doing it from stock it doesn't need to get better.
                      I was going to keep this for myself but I might just sell it on until I get my hands on a Sony or something.
                        As you said you only notice it on no input screens so I can't see it being an issue.
                        Samsung and LG are okay too, once fixed. Better than Vestel. Fixed 4 Samsung LCDs + 1 Samsung plasma and 2 LG LCDs + 2 LG plasmas my self. Usually quite easy to fix once you get the meter out and test things.
                        • DoctorWedgeworth
                          • Jul 2012
                          • 65
                          • England
                          Nah it's not just input screens, it's any silence is replaced by it. It's actually constant and noticeable between gaps in sound (you learn they're quite frequent!).
                          Can I use my basic DMM to figure out which capacitor it might be?
                            No, for this kind of problem, you need a scope to trace the noise source.
                            • DoctorWedgeworth
                              • Jul 2012
                              • 65
                              • England
                              What's a scope? I tried searching for it on Google and products on Amazon but I'm coming short. I saw an article about removing capacitors then connecting them to a multimeter, the resistance should start at zero and move to infinity. Will that not work here?
                              For testing the voltage going to the speakers will I need to find the instruction manual?
                                Oscilloscope. Lets you view the voltage waveform with respect to time. They run from £40 to £140,000.
                                The Rigol DS1052E is an ideal scope, starting new from £250. You can also get a cheap analog scope (fine for most tasks) for less than £100 in most cases.
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  a scope is an "oscilloscope" used for measuring waveforms,voltage,ripple current etc.
                                  you can use a meter to give an indication that the cap is charging and discharging,an analog meter is better for this,normally called a "kick test",to test the condition of a cap ,you need an ESR meter,it will give you the impedence of the cap,the readings need to be in spec with reference to a datasheet,some also give the uf of the cap,and so will some digital/analog meters
                                  i suggest you check first, the output voltages (dc) against there pcb marking,at least it will tell if the psu is outputting what it should be.
                                  mark each connector down ,with the pin number ,and its voltage marking,and its actual reading that you measure.
                                  example:
                                  c100 pin 1 voltage 12v measured 12.68v
                                  pin2 voltage 5v STB measured 5.33v
                                  or
                                  conn 26 etc etc
                                    Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                    by momaka
                                    More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                    02-15-2022, 12:43 AM
                                    Connect pc speakers to tv without 3.5 jack
                                    by nomoresonys
                                    Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
                                    09-19-2025, 05:17 AM
                                  • Widget
                                    Logitech R20 speakers - Replacing one of the speakers.
                                    by Widget
                                    Hi guys,
                                    I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                                    Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                                    Printed on the back of the Logitech speaker is;
                                    LOGITECH...
                                    05-29-2024, 07:07 AM
                                  • Jaime Morillo
                                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                    by Jaime Morillo
                                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                    The TV was stuck on the logo and I couldn't access the update menu.
                                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                    The image result was good, but the image is inverted.
                                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                    08-18-2025, 11:38 AM
                                  • RetroComputingGrotto
                                    Behringer MS16 Speakers - Low Volume on One Speaker
                                    by RetroComputingGrotto
                                    I've had a set of speakers come in with the fault of not powering on.
                                    I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
                                    1 random loose nut and part of a BIC Biro pen.
                                    After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
                                    05-20-2024, 07:29 AM
