toshiba 32av502u dead no power
  • jkbarto
    • Jul 2012
    • 17
    • usa
    had power outgage from utilty company,when power came back up
    tv was dead no power, no light, checked power board ,blown fuse ,replaced fuse , blew again, ordered new power board and replaced,still no power on tv
    checked fuse good,but only has 48-50 volt at fuse ,is this voltage ok
    is this replacement board bad or is there another board that might be bad?
  • selldoor
    Slow Learner
    • 7870
    Re: toshiba 32av502u dead no power
    If you are talking about the mains fuse then no , it should be 120VAC or close. Check the lead and the fuse holder - is this on the New board?,
    tray another lead?
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • retiredcaps
      • Apr 2010
      • 9271
      1) How are you measuring the fuse?
      2) AC or DC?
      3) Where are you putting the black and red probes when measuring the fuse?
      --- begin sig file ---
      --- end sig file ---
      • jkbarto
        • Jul 2012
        • 17
        • usa
        red lead is at fuse and black lead on ground screw i get 48 volt ac
        if i measure from fuse on red lead and white on ac cord i get 120 volt
          Unplug the TV from the outlet, set the Meter to the lowest Ohm scale, I.E. 20 or 200. Red probe on one end of the fuse, black probe on the other end of the fuse, report back what you read.
          • jkbarto
            • Jul 2012
            • 17
            • usa
            i get 1.3
              I expect it to be less than 1 Ohm but that may be due to probe lead resistance and weak batteries in the meter.
              Next, set the meter to DC high range above 250VDC, put the meter probes on that large brown/black cap with two exposed legs in the pictures, be cureful since you are working on the line voltage, polarity dose not matter since the digital meter does not care, I expect to see around 170VDC on that cap with the TV plugged in. BE CAREFUL!
              • retiredcaps
                • Apr 2010
                • 9271
                One retiredcaps' bonus point for a picture your Beckman Tech 310 multimeter.
                The reason you are getting 48V AC is because you are using chassis ground.
                Your reading of 1.3 ohms suggests the fuse is likely good. I say "likely" because if your multimeter reads around 1.0 ohms with the leads touching, then the fuse is actually 0.3 ohms.
                edit: Budm beat me again by 1 minute!
                • jkbarto
                  • Jul 2012
                  • 17
                  • usa
                  here are picture of chassis and boards
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Originally posted by budm
                    next, set the meter to dc high range above 250vdc, put the meter probes on that large brown/black cap with two exposed legs in the pictures,
                    c102.
                    • jkbarto
                      • Jul 2012
                      • 17
                      • usa
                      cap reads 165vdc
                      • selldoor
                        Slow Learner
                        • 7870
                        Ok looks like it might be ok just as a last check. Meter on 200 VAC measure from the white lead to each end of the fuse- you did one end please do the other end.
                        Next test - Board powered on -CARE HIGH VOLTAGE meter on 600VDC put red probe on to + leg of the BIG Cap and Black Probe onto negative leg of the BIG Cap
                        WOW you lot are keen - im off to bed.
                          OK, if you look at the left side of the board, you will see P802, you can see that it has label on the board telling you what you should have at the pins, in this case, with the TV is not turn on but plugged in, you should have standby 5Vdc voltage at pin 10, 11, 12 of P802 as shown on the board, black probe on the chassis, red probe to the pin we are testing.
                          • jkbarto
                            • Jul 2012
                            • 17
                            • usa
                            white power lead and other lead to fuse 120volt
                            black ac power lead and other lead to fuse 0 volt
                            cap at c102 is 165vdc
                              See post 13.
                              • jkbarto
                                • Jul 2012
                                • 17
                                • usa
                                pins at 10 11 12 no voltage ,no voltage on any pins ,p802 goes to processor/tuner card
                                  That explain why you do not have any indicator lights, and dead set. We need to troubleshoot the 5V standby power supply section next.
                                  It is generated from that small transformer T001 and that 8-PIN IC, cannot read the number due to the flash glare. Please get the P/N as printed on that IC so we can look up the spec and see how it works.
                                  • jkbarto
                                    • Jul 2012
                                    • 17
                                    • usa
                                    pk101v0730i
                                    • jkbarto
                                      • Jul 2012
                                      • 17
                                      • usa
                                      top view
                                        That is the number of the board, I need the P/N of the 8-pin IC on that board
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
