Panasonic TC-42PX14 Zener Diode
  • mr.sky
    • Sep 2011
    • 54
    Hello, this Zener Diode is on the A-board, it is part of
    the 15v rail that leads to IC5608 and 5607. In an earlier
    post I have attached the Schematics.
    Can someone identify how many volts this Zener Diode is.
    Panasonic parts does not identify the Diode. Suppose they
    want you to buy from them. Unfortunately they do not
    stock it.
    Thanks!
  • Mt.Man
    • 53
    Re: Panasonic TC-42PX14 Zener Diode
    Do you have the diode location number Dxxxx?
    • mr.sky
      • Sep 2011
      • 54
      D5573 It is near the 9v regulator IC5401
      • JimmysTGP
        • May 2012
        • 45
        • US
        I must be blind, read me the colors off the diode.
        If it is a red, Black, Green. Then it is a RLZ12
          Can you please give me the link to that schematic?
          • Mt.Man
            • 53
            Panasonic part number B0BC01100001. However they do not say what voltage rating it is. Its on the output of IC5401 which is the Sub9v. Most likely used for protection. Just guessing maybe 10v or 11v. Input to IC5401 is 15V.
            • JimmysTGP
              • May 2012
              • 45
              • US
              I guess theirs two ways we can attack this, but if your ability to see the diode as well could ultimatly swing the other. Just remember your dealing with a LL-34, hope this helps.
                If it is used as a protection, that means its Zener voltage point will be higher than the output voltage of the IC5401, so the circuit should still function without it and you can also measure the output voltage of the IC5401 and then use Zener Diode that is about 2V higher than the output voltage.
                • mr.sky
                  • Sep 2011
                  • 54
                  Sorry guys, did not respond yesterday. Ended up in hospital
                  with Great Pains in Abdomen, after Ctscan, I have a Inflamed
                  Colitis. So much for that.
                  yes, the color is red, black green.
                  I am not getting 15v to the diode or to IC5401, reading is
                  5.4v to both components.
                  • mr.sky
                    • Sep 2011
                    • 54
                    budm: here is the link to Schematic
                    http://www.mediafire.com/file/pgdrdbmc2ynu9km
                      It is big download file, downloading it, can you please point to which page this circuit is on?
                      • mr.sky
                        • Sep 2011
                        • 54
                        Page 30 and 46
                          Ok, the IC5401 is a 9V voltage regulator, so the Zener Diode may be 12V Zener.
                          So next thing for me is to find out what generates the F15V source.
                          • mr.sky
                            • Sep 2011
                            • 54
                            budm, read Slide #28 the last paragraph. I think this is why
                            I am not getting F-15v from outpins from power supply board.
                            There is a 3.3v 6pin voltage regulator on the component side of
                            the A board, maybe this is the one that triggers the command to
                            to acitivate the The PANEL MAIN ON command turns on the power supply circuit that outputs the Vsus, Vda, 15V, and 5V.
                            Let me note my A-board does not have IC 9004
                              OK, I figure out where the F15V is generated from, see PDF/JPG attached.
                              This F15V is called F15V_STBY which is the always on standby power supply.
                              So you need to check the voltage at the IC502 which generated the regulated F15V voltages for a lot of circuits as I redlined.
                              • mr.sky
                                • Sep 2011
                                • 54
                                budm, Thanks for the diagrams. let me update you and others who
                                are following this thread.
                                On first diagram where IC502, I am not getting 15v at all.
                                Before I press the power button, reading is at 3.0v. Once
                                I power up unit it goes to 5.4v, same reading I get at the
                                A Board at IC 5401 and IC5608.
                                Also, Pins 7,8,9 same voltages at connector P6.
                                The unit is only come on for a few seconds, enough to take
                                a reading then shuts down within 5 seconds.
                                Note, I took the reading from pin 4 of IC502
                                  IC502 is the standby power supply (15V) which should be always running. The other power supply circuits is right below it is also always on, do you get any voltage there? There should be voltage at Q505, that section is for the standby 5V power supply.
                                  Basically, transformer T200 is for standby 5V and standby 15V power supply, so you MUST have these voltages.
                                  • mr.sky
                                    • Sep 2011
                                    • 54
                                    I will check it out, I also tried another new power supply board
                                    that I received last week. And the same results.
                                    Who knows could be bad too, good thing I got it for 30bucks.
                                    I am looking at page 32, and on top of board, there is a 3
                                    leg diode, looks like a regular size voltage regulator, but it is
                                    a diode, D502. Going to have lunch and test voltages like you
                                    mentioned above.
                                    • mr.sky
                                      • Sep 2011
                                      • 54
                                      Will take those voltage readings tomorrow, seems my Amprobe 38
                                      meter, needs another battery. Readings flucuate.
                                      budm, so standby should always be there, without powering up
                                      unit, correct? The only voltage i get on P6 connector is the
                                      5vstandby. That is with just the power cord plugged in.
                                        Yes, the standby power supply will start running the minute the power plug is plugged into the outlet. All TVs need standby power supply to run the processor on the main board and the remote receiver so it will be ready to take command to turn on the rest of the power supplies from the power switch or from the remote control. This is how TV uses less power when it is not on.
                                        Are you getting any DC at IC502 PIN2 VCC input pin? and the voltage reading on the rest of the pins of IC502.
                                        Since you are getting the 5V, that means the transformer is working.
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
                                        • Vincenzo2
                                          Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                          by Vincenzo2
                                          My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                          Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                          I put some pictures here to show that it is labeled "M7"....
                                          09-07-2023, 07:43 PM
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
