Panasonic tc-l32c22 lcd
    Re: Panasonic tc-l32c22 lcd
    no blink codes, no red light nothing at all
    Originally posted by randtek View Post
    By the way, are you getting any blink codes on the Power LED? Or is the unit completely dead.
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
      Tom,
      The 20 pin IC says H3475 OR H5475, not too sure
      Jon
      Originally posted by selldoor View Post
      Tom means the number that hopefully is on the IC with 20 legs that is ringed in red on the picture. You may need a magnifying glass and try rubbing it gently with isopropyl alcohol.
      If it is the same as the tv number I apologise.
        Selldoor,
        Thank you for the illustrations. This is starting to make some sense to me a bit now. I will continue to study until I have the Power Supply conquered, then of, course, I will have to move onto the Main board and Inverters. Hopefully
        Originally posted by electronicsurplus View Post
        So, correct me if i am wrong. It looks as though the 115V goes to the fuse and then to the Rectifier, then to the 5V standby transistor so, if no 5V I should look to this transistor
        I think i will find a properly working power supply to determine
        I apologize IF i seem dumb but, I obviously am. I must be skipping some chapter or something because, I am surely missing something here
        Thank you for your help in trying
        I guess I will just need to study more to hopefully someday understand
        Jon
          Originally posted by multimeter View Post
          if the tv worked with a new supply,but didnt when reassembled ,i would take the back off again and reseat all connector cables,(unplug and re-plug in),and making sure the psu ground points are grounded,and have a check and double check on the tv's side buttons.the little tact switches if jammed will cause this problem,if one jams on, the set will sense it and not respond to remote or the side buttons
          But, at least it should have a red light when plugged in but, it does NOT
            OK - let us start again. Get the power board and the main board you used when it briefly started up and post a good clear in focus picture of each side of each board.
              Here are some more pictures
              Thank you
                Selldoor,
                funny thing is this board has 6V instead of 5V. I also have the service manual available on Tom66 website.
                Hope you can help me figure this set out. making me crazy
                Jon
                  was trying to upload the entire pdf of the tech guide but for some reason i'm getting fail to upload So here's this hope it helps
                  Ron Driver,BSEE,CET,ISCET,NESDA
                    Ron,
                    What is that from?
                    PM me or email electronicsurplus@cox.net
                    Jin
                      I am sorry I am not even going to try and look at them again - please can you look and enlarge them and tell me if you can make anything out of the blur. If you can then I am off to the opticians tomorrow.
                        Here are some more
                          here with service manual
                            Will not allo me to upload service manual
                            But, it is available on
                            tom66 website
                            See: http://www.tgohome.com/ServiceManuals
                            If this helps at all
                            Thank you for ANY and all help. I truly appreciate it. This set has been driving me up the wall and, ready to just scrap it
                            I am not very good at reading and understanding schematics yet but, will be soon, hopefully
                              Right - First problem - according to the SM there are 4 fuses The main one is F7001 and I can find that cos I know where it should be. The others F801 F802 - not sure why they have 3 numbers not 4 I cant see - on another board?
                              and F7801 looks like it should be on this board but although the pics are better I cant see it - can you?
                                I have this same problem. I'm new here and not even sure how this works.am I posting in the right area? Can someone walk me through this set please
                                  Hello i am new here i have a problem i turn on this tv and 10 min shut off and blinking 4 times red led i have service manual for this tv and say this fault is DTV12V line but i verfique smd transistors and zener diode for protection area all ok i check psu and only replaced big electrolitic cap 450v 120uf is reading 101uf but tv same a problem waits long time disconec conect again power on ok all working fine but 10 min power off and blinking 4 times red led any help for this model thanks sorry my bad english
