Memorex MLT4221P stuck in standby
  • gb77
    curious
    • Aug 2011
    • 76
    #41
    Re: Memorex MLT4221P stuck in standby
    should i take 470 - 820 as a range? or do you mean i should find 2 caps that add up to something near 1360 total?
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      If you can't get two 680uF, then get one 470uF and one 820uF so the total is close to the original.
      --- begin sig file ---
      --- end sig file ---
      • gb77
        curious
        • Aug 2011
        • 76
        #43
        replaced the caps, and readings are still the same. have a look at the large Illinois Capacitor surplus caps in place. thanks for your ideas. maybe you have some more? i sent a request to the power supply maker for a schematic telling them i was troubleshooting why the 18v line was only at 11.8v. dunno if such places ever respond to such requests.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          1) Geez, those are huge.
          2) The inductor right by those two new huge caps is partially covered in white glue. A long shot, but try resoldering the two solder joints on the back of the inductor.
          3) My spatial mapping skills are not the greatest so I can't tell if the 4 circled transistors are part of the 18V rail or not, but test each one to see if they are shorted between pins 1-2, 1-3, and 2-3. Report all your readings.
          4) You also have 8 SMD diodes in that area. You might as well test them all and report the 16 readings (2 per diode).
          • gb77
            curious
            • Aug 2011
            • 76
            #45
            ok - the real fun begins. friend comes up with $ to buy the p/s from shopjimmy. it arrives & i install it, connecting only the 5v load - the 18v line is @ 11.8v (24 is 24) on the new one too. disconnect power, plug in the 18 & 24 v connectors, connect power and tv remains in standby.
            any ideas?
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              any ideas?
              Okay, assuming the shopjimmy board is good, let's check the main/logic board. I circled 4 voltage regulators. There may be more, but that is all I can see in the photo.
              To test a voltage regulator (circled in red),
              1) Set your multimeter (if manual range) to 20V DC.
              2) Put your black probe on a ground screw (circled in black). Leave it there the entire time. This is your ground.
              3) Put your red probe on each of the pins including the "cut" pin, but ignore the "fat" tab. The fat tab is "up" or "north". Number the pins left to right.
              4) You should have 3 readings per regulator.
              5) Report them like so along with the part number (include all lines on the IC) of the IC.
              U100
              AS1117-33
              pin 1 = 0.0
              pin 2 = 3.3
              pin 3 = 5.0
              • gb77
                curious
                • Aug 2011
                • 76
                #47
                from top to bottom of the ones you circled
                utc
                78T05AL
                05 UGBS
                11.77 0 4.94
                this one has a glob of glue on it
                1084
                PE
                507D2
                2.05 3.29 5.0
                A1
                AS1117L
                80737 92
                0.6 1.3 3.29
                same as previous
                0.25 1.49 3.29
                2 more on left side of mainboard (you can see them in attachment https://www.badcaps.net/forum/attach...2&d=1339903244 )
                A1
                AS1084S3
                A0723
                1.37 2.62 5.01
                1084
                PE
                507D2
                2.04 3.28 5.01
                that 1st one has the 11.8v going on - any significance?
                • gb77
                  curious
                  • Aug 2011
                  • 76
                  #48
                  searching mouser & digikey for 78t05 yields some results, but nothing in stock - showing 3A 5v max output
                  http://www.datasheetdir.com/78T05+Regulators
                  shows 0.5A - clik link to datasheet pdf - the ---05 on the chip indicates output is 5v
                  http://www.datasheetdir.com/78T05+download
                  looks like 11.77 is the input v & 4.94 is output
                  if i disconnect 18v load from p/s the 11.77 goes to 0
                  • gb77
                    curious
                    • Aug 2011
                    • 76
                    #49
                    if for some f-d up reason the 18v line was supposed to run @ 11.8 for this tv.. what would be the next steps to see what was wrong?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      A1
                      AS1117L
                      80737 92
                      0.6 1.3 3.29
                      same as previous
                      0.25 1.49 3.29
                      Okay, we may have found the problem. The AS1117L is an adjustable voltage regulator. The correct output for pin 2 (middle) is based on this calculation:
                      DC V of pin 1 + 1.25V = output of pin 2.
                      As you can see, the bottom voltage regulator is
                      0.25 + 1.25 = 1.50 (you have 1.49 which is close enough).
                      The first voltage regulator is
                      0.6 + 1.25 = 1.85 whereas you measured 1.3 (more than 30% off).
                      So confirm that the readings on pin 1 and 2 are 0.6 and 1.3 respectively. If yes, that voltage regulator is likely bad. I say likely because there may be cap that is pulling down the voltage on pin 2, but in 90% of the cases I have seen, it is likely the voltage regulator.
                      This replacement should work. You might want to get 2.
                      http://www.digikey.com/product-detai...98-1-ND/705738
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        The capacitors just above that suspect voltage regulator looks like a crop circle in the farmers field. I have never seen that before.
                        • gb77
                          curious
                          • Aug 2011
                          • 76
                          #52
                          https://cdn.badcaps-static.com/pdfs/...9aecb4a8ce.pdf
                          addendum pg 5 shows TI will send out samples of this one. i got samples from TI or someone maybe 10 yrs ago. looks like i need to set up an account
                          https://focus.ti.com/tipass/docs/reg...?&actionId=368
                          is it still simple where i can say i'm a student or is there some verification / hassle now? any suggestions?
                          • gb77
                            curious
                            • Aug 2011
                            • 76
                            #53
                            ok, ordered 3 samples - will have to practice similar smt soldering while waiting
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #54
                              I use a non temperature controlled heat gun on low heat to remove these types and I use Kapton tape to cover all the surrounding components so they are not damaged by the heat from the heat gun. With this method, it takes about 30 seconds to remove.
                              • gb77
                                curious
                                • Aug 2011
                                • 76
                                #55
                                got the chips - decided to triple check what was going on, noticing a couple more identical AS1117L chips to the left of the 78T05AL. figured i'd measure them too, getting 2.04 / 3.29 / 4.99 & 2.04 / 3.28 / 5.02 which matches the 1.25 bump. took another measurement of the suspect chip, and found i must have made a transcription error ( & failed to notice .6 =\= .06 on my double check) as it does measure .06 on pin1 and not 0.6 - so it checks out within .01v. so on to the next line of inquiry i hope - for now i have some spare chips! thanks for your next ideas.
                                • gb77
                                  curious
                                  • Aug 2011
                                  • 76
                                  #56
                                  still looking for some help here. since i dont have the remote, and the power switch doesnt do anything, i checked voltages going to the power & other buttons. all read 0. checked the inverter boards, and both are getting 24v & have good fuses, with I-PWM @ 3.28v. thanks for any ideas on what to check next.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    I'm out of ideas right now. My brain needs a break for a while and I think the watching the Olympics will help me do that.
                                    • gb77
                                      curious
                                      • Aug 2011
                                      • 76
                                      #58
                                      thanks for the help so far retiredcaps - i'm thinking to 'buy/rent' a mainboard from shopjimmy for ~$97/20 (return charge) to see if a replacement will bring any joy. if there are any precautions you would suggest before swapping them, i'd appreciate that.
                                      if anyone else has suggestions i'd be glad to hear them too. i looked over my old post about a samsung that ran a 5v, (11.8 on) a 12v & 24v from the p/s. which makes me wonder if the board markings of 18v dont necessarily mean all versions of the p/s run 18v.
                                      enjoy the olympics - i will too - 2 tvs at a time - or 3 for a while if i fix this one too.. lol
                                      • gb77
                                        curious
                                        • Aug 2011
                                        • 76
                                        #59
                                        new main board from shopjimmy is in and the tv is working again. put in old power supply with oversized caps & it works fine too with the "18v" line running @ 12v. should i put back the original caps, the large caps dont allow the heatsink plate to go back in flush - see the link for the plate on the right - reasons why or why not?
                                        https://www.shopjimmy.com/fsp-fsp271...wer-supply.htm
                                        i will take some voltage readings from the new mb to see if they differ from the old. since i have a good one, are there some other tests i can do on the old / new to compare and find the problem? for now i'm renting the mb for 30 days @ $20 - thanks for any help
                                        • gb77
                                          curious
                                          • Aug 2011
                                          • 76
                                          #60
                                          mb voltage readings are same with a few pins .01-.03v difference.
                                          post 43 has my pic of the power supply with very large caps i refer to in my last post.
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
