Greetings!
I have a Sanyo DP42848 that I got very cheap because it was broke. The people had taken it to an actual repair shop which diagnosed it as needing new inverter boards. This was very obvious as the boards looked horrible, I'm thinking they overheated. Anways, I replaced both boards with new ones and now it turns on with only the left side lighting up and then the backlight shuts off. I'm assuming the protection circuit is shutting off the backlight because of whatever is causing the right side to not light up. I am very skilled with electronics repair, but do not have a lot of experience with TVs. What I am thinking is I either got a bad inverter or the power supply is bad. Any guidance you can provide to help with troubleshooting is greatly appreciated.
