Re: Rca l37wd12 lcd tv
Search the model number on Shopjimmy it may show up there if not you can ask them about it.
Rca l37wd12 lcd tv
I have a RCA L37wd12 I got for free. I replaced one cap on standby board and now it is working fine but I noticed it is missing the IR sensor board so I can't use a remote. Does anybody know what the part number is and where I can find one?Leave a comment:
i have an Rca l37wd12 lcd tv i got for a steal 26 bucks when plugged in the tv turns on but no picture or sound i have it apart so when i plug it in i hear the relay click on on the 1w board but nothing a few seconds later there is a read light on the back-light master inverter board that comes on then shuts off the stand by light turns green but after awhile will go back to red any help at all would be greatly appreciated i do appoligize about my bad spellingLeave a comment:
What happened to your old power supply? do you still have it available for spares?
If this one worked for a while then stopped did you or previous owner use low esr caps
bought off a reputable dealer have you. I would try and clean up the soldering - may be the picture but some joints look cold and some could be bridged- magnifying glass job.Leave a comment:
ok can you give me clear shots of the connectors that you have tested.
Also you state the fuse was open... which fuse was this?Leave a comment:
Well, me just being stupid, didn't check the fuse. The fuse was open, I replaced it but still no joy. I will take it back out and see if the fuse blew again. Anyone have a schematic of this power supply?Leave a comment:
Ok, here are some pictures...the capacitors that typically fail have been replaced, not a great solder job but didn't have much to work with since I bought this power supply on ebay and believe the previous owner attempted a repair. This power supply worked for awhile but now has quite working. As I stated before I can control the on/off signal providing the 120v to the power supply. On the output connector all I am seeing is 3.1v on Pin 1 of the 7 pin connector which I assume is a on/off signal as well. Any ideas?Attached Filesif you find these attachements useful please consider making a small donation to the site
You have the ideaI will try to post some pictures tonight...I at work right now and honestly I haven't looked at it for about a week so I will try to get it back out and do some investigating as well.
Based on the interconnect diagrams and what I understand on here...when I hit the power button it sends a signal to the scaler board and the scaler board goes to the 1W power board and turns a relay on that supplys the 120v to the SMPS which then supplys the 12v and 24v signals. Does this sound accurate?
Based on the interconnect diagrams and what I understand on here...when I hit the power button it sends a signal to the scaler board and the scaler board goes to the 1W power board and turns a relay on that supplys the 120v to the SMPS which then supplys the 12v and 24v signals. Does this sound accurate?Leave a comment:
To save me jumping around can you take a pic of your boards... DMM at hand?I know that this is an old thread but I believe I am having trouble with my power supply on this model. I am getting the on and off signal because the 120 volts supplying the power supply comes on and off. However, I am not getting any outputs from the power supply. I have already replaced all the capacitors with FM Panasonic's but still no help. Any other suggestions on where the failure my be or a schematic of the power supply board itself.
Thanks!Leave a comment:
I got my replacement main board today, installed it and am now posting this from the working TV. I'm using it as a 37" computer monitor since I didn't bother replacing the analog tuner connection which has been snapped off.
All I wanted it for was to use as a computer monitor and that's what it's doing!
Total cost ~$80 CADLeave a comment:
no worries budm,
I found a used main board on ebay that I have ordered. no rush for the schematic right now, though if the replacement doesn't work I may ask again.
Thanks for looking for me!Leave a comment:
Sorry, been real busy. the drawing is so big, I do not think I can take good pictures that is good enough to read, I will try to scan it into PDF using printer at work.Leave a comment:
any luck budm?
I'm trying to source a main board in case I can't repair this, but they aren't very plentiful.Leave a comment:
I hope to be ordering an ESR meter soon so that I can try and test some of the SMT caps on the mainboard.
budm, would I be able to pester you about a schematic for the scaler board if there is one?Leave a comment:
just bumping this back up. I haven't had a chance to trace the button line yet, I will hopefully be doing that tomorrow evening.Leave a comment:
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
