Insignia 47 LCD (NS-LCD47HD-09)
  • SidRo
    • May 2012
    • 8
    Problem:
    After watching TV for a random amount of minutes the picture fades out rapidly and I have to turn the TV off/on to see picture again. FADE/POWER/REPEAT.
    Tests:
    Backlight IS still on.
    No picture exists with flashlight check.
    Sound works fine whilst picture is absent.
    Purchased MB ... still fades out.
    Purchased PSU Board .. still fades out.
    When picture fades, menus (nor anything) are visible.
    After PWR 1/0, TV works immediately until Fade/PWR/RPT.
    Hypothesis:
    T-Con
    Backlight Inverter (But just cant see how this is the issue)
    Need new cables between MB and TCON/Inverters
    Can anyone confirm a solution before I purchase ANOTHER friggin' part!?!?!
  • Mr Bill
    • Nov 2011
    • 648
    Re: Insignia 47 LCD (NS-LCD47HD-09)
    Originally posted by SidRo
    Problem:
    Tests:
    Hypothesis:
    T-Con
    The tcon is about all thats left. Have you tried to remove the back of the tv and place a fan blowing on the boards to see if it works longer?
    • SidRo
      • May 2012
      • 8
      I have not ... I can try that - should that fail ... get the T-CON?
      • Mr Bill
        • Nov 2011
        • 648
        If it works, meaning the picture stays on indefinitely, then the next step would to somehow get air to hit the tcon board only. That would indicate that something on that board is overheating and causing it to shut down.
        • SidRo
          • May 2012
          • 8
          10-4 Testing tonight will repost results later.
          • SidRo
            • May 2012
            • 8
            Holy Skid Marks, Batman!!!
            Check this out .. I pulled off the TCON shell and look what I found...
            BURN MARKS!
            Running TV now with shell off / back of TV shell off / Fan pointed at TCON.
            Started at 10:30 will see how long it lasts.
            • SidRo
              • May 2012
              • 8
              Sorry here are the pics.
                Used T-CON is about $70.
                http://www.shopjimmy.com/cmo-35-d027939-t-con-board.htm
                You may want to check the output voltages of the Regulator ICs.
                • SidRo
                  • May 2012
                  • 8
                  Taking off the shell seemed to do the trick ... Has been running for two hours now. Thanks Mr. Bill and Budm for the assist. I will let it run overnight but so far this has been running longer than I have ever had it. Go figure ... After $220 in parts ... the fix was free!!!!
                    The metal plate is used to heatsink the main processor. What is likely happening is some component under the heatsink doesn't like it. Without a heatsink the processor will probably overheat and fail.
                    I have several "well used" T-con boards (working ones) and they all show discolouring around the shield, it's not unusual.
                    • SidRo
                      • May 2012
                      • 8
                      No .. its still working haven't turned off yet. Thanks though.
                      • SidRo
                        • May 2012
                        • 8
                        Thanks all ... I will get a new TCON but for now the removal of the outer plate is keeping it cool enough to function as designed.
                          You could try using a heatsink from an old motherboard to do the job.
                          • pixelSHREDDER
                            • Oct 2014
                            • 5
                            Just checking in to say that this solution totally worked for me, and I now have a brand-new(ish) 47" Insignia to show for it! Thanks!!
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • srs
                              Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                              by srs
                              I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                              A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                              I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                              04-22-2023, 02:40 PM
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • jose6326
                              Insignia Ns-l22x-10a no picture only sound
                              by jose6326
                              When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                              When i was removing the back cover i heard a rattle.
                              Removed the metal plate and the heat sink was off (see pic)
                              would this cause a no picture/image issue?
                              What is used to put back the heat sink
                              07-30-2024, 11:03 PM
                            • S14Sr20det
                              Nec E557Q lines and fade to black picture FIXED
                              by S14Sr20det
                              Trash picked this tv from a local business, had a garbage image and would fade to black within second then cut off. It would get shorter and shorter every time.
                              Narrowed it down to the right side of the panel by unplugging half the t con
                              One side had a great picture the other was black and distorted still.
                              Down to the buffer boards… found yet another set of two esd diode arrays. One leg had a 60 ohm short to ground and would get lower the more attempts made to turn the tv on.
                              Soldering iron and some chip quick knocked both of them off and...
                              06-17-2023, 02:55 PM
