Sanyo DP46840
  • lilmonk3
    • Apr 2012
    • 259
    Re: Sanyo DP46840
    I seem to have all the proper voltages except for K8L.. 2 black wires and 1 white wire.. White -0
    Black- 0
    Black - 3.3v
    • kevinm34232
      • May 2012
      • 1884
      Re: Sanyo DP46840
      Did you get service manual though? It has test points for the 5 or so shutdown circuits which makes it fairly simple to determine where the issue is..
      Did you say it was DP42840-01? You had some typos
      • kevinm34232
        • May 2012
        • 1884
        Re: Sanyo DP46840
        See if you have these test points, this is from the -00 chassis..
        • lilmonk3
          • Apr 2012
          • 259
          Re: Sanyo DP46840
          Originally posted by lilmonk3
          Dp42540 Chass. P42840-01
          Its Dp42840
          • lilmonk3
            • Apr 2012
            • 259
            Re: Sanyo DP46840
            Here is a pic of the area on the main.. But I an not sure where or even how to test those points
            • kevinm34232
              • May 2012
              • 1884
              Re: Sanyo DP46840
              Can you take a good pic of the entire main board, what is the # on the white sticker on the tuner N7A*...? It's not easy to find some of those points but they are there!
              • lilmonk3
                • Apr 2012
                • 259
                Re: Sanyo DP46840
                Here are some close ups .. White sticker is N7AM
                • kevinm34232
                  • May 2012
                  • 1884
                  Re: Sanyo DP46840
                  Here are 4 PF test points, you should see some other points as well on the board with white stars around them.
                  Be very careful not to let the red probe slip when testing. Black probe to chassis ground.
                  • lilmonk3
                    • Apr 2012
                    • 259
                    Re: Sanyo DP46840
                    Thanks Kev..I might not have time to get to it until the weekend...
                    • tvcoach
                      • Jan 2010
                      #90
                      Re: Sanyo DP46840
                      There is a service bulletin on this to change IC1670 and add a 18V zener
                      • selldoor
                        Slow Learner
                        • 7870
                        #91
                        Re: Sanyo DP46840
                        Tvcoach - that is great is there a link to the bulletin?
                        • BoJaXz
                          • May 2013
                          • 19
                          Re: Sanyo DP46840
                          Hi, I have the dp46840 with the dp46840-00 chassis. The tv I have doesn't click when you plug it in or turn it on. When you turn it on, the green light comes on for about 3 seconds, then turns off. After three tries, it locks down and you have to unplug it. nothing comes on the tv, just black during the 3 seconds. Any ideas? I have a multi meter and am ready for direction. I'm assuming since the transformer didn't click, that there's an issue there. Any takers for helping this noob? :-)
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Re: Sanyo DP46840
                            It's best to start a new thread. Here's the service manual if you don't have it already.
                            • BoJaXz
                              • May 2013
                              • 19
                              Re: Sanyo DP46840
                              I got the service manual after I posted. I did the test points and the audio power was supposed to be 13v and it's only 2.8. So I'm guessing it's the lv5806 step down converter. I can't find the actual ic001 audio amplifier chip. Unless it's on the back side of the board. And the same with d1671 to bypass the pfail circuit.
                              • kibbles67
                                • Dec 2015
                                Re: Sanyo DP46840
                                Hi new here but have the same tv and same problem would it be just as easy to replace the boards? The power supply board and the main board.
                                • kibbles67
                                  • Dec 2015
                                  Re: Sanyo DP46840
                                  The next question I have does anyone know the best place to get those for the best price?
                                  • cj_reha
                                    Mystery 80s Sanyo cap - perhaps polymer?
                                    by cj_reha
                                    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                    01-06-2023, 09:24 AM
                                  • Srdjan01
                                    IPhone 12 ProMax - Thoughts of (not so young) apprentice
                                    by Srdjan01
                                    Hi guys.
                                    I'm working on my first board reballing.
                                    It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
                                    Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
                                    I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
                                    03-17-2025, 02:49 AM
                                  • toddw65
                                    Sanyo DP5834 - Gray Screen
                                    by toddw65
                                    Hey All,
                                    I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                                    Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                                    Thanks,...
                                    10-31-2024, 10:37 AM
                                  • zomi
                                    Manual cof bonding success rate ?/ feedback wanted
                                    by zomi
                                    Just wanted to get some feedback,
                                    whats peoples' success rate with cof bonding repairs.....
                                    09-23-2024, 12:45 PM
                                  • valvashon
                                    Repair Success! Middle Atlantic UPS2200R-IP
                                    by valvashon
                                    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                    02-06-2024, 12:54 PM
