Sanyo DP46840
  • kevinm34232
    • May 2012
    • 1884
    Re: Sanyo DP46840
    Yes I did that earlier:
    OK so going thru the service manual it shows 4 power failure circuits to check:
    IC 1630 I'm getting a steady 3.1vdc not 3.3, is that an issue?
    Audio.Pow IC1670 is where I think the problem is, gets 24v in, but out is sporatic, winds up at about 3vdc before shutdown.
    IC 1660 is good, 9v
    and 12V supply is good.
    Had 3.1vdc at IC1630 instead of 3.3v
    and also erraric readings and Audio Pow
    So what can I check at about that low voltage at IC1630?
      Re: Sanyo DP46840
      The switching buck converter IC1630 LV5803M (PAGE 45) can take input from 4.5V ~18V and should maintain the output voltage as determined by the resistors (see spec). So it looks like it is not working properly at this point. Its internal reference voltage may be bad.
      I would try a new IC or some sort of 3.3V external power source.
      So far I cannot find that 12V regulator that convert 24v to 13v for the audio section as mention on the link.
      • selldoor
        Slow Learner
        • 7870
        #43
        Re: Sanyo DP46840
        Do you mean cant find the data sheet?
        Is this any help?
        • kevinm34232
          • May 2012
          • 1884
          Re: Sanyo DP46840
          Will this work for that IC1630 or no? It says 5v output.
          http://www.mouser.com/ProductDetail/...52bNuFsA%3d%3d
          One other interesting thing that makes me think the audio IC is (or atleast part of) the problem: Normally when I turn TV on, it takes about 10 seconds for power failure circuit to shut down. But when I put my DMM on the audio IC to read voltage, the TV shuts down much quicker, around 5 seconds.
          • selldoor
            Slow Learner
            • 7870
            #45
            Re: Sanyo DP46840
            If you check the data sheet for that product at mouser you will see it is the same as
            Budm posted above - so I guess it will be ok. Can you do the external source test before you order - just thinking of postage and minimum order charges, if they apply. My question as I dont know the answer would be can it be more than 3.3v as 3.6v is easier to come by.
            • kevinm34232
              • May 2012
              • 1884
              Re: Sanyo DP46840
              Are you saying to get an external source of around 3.3v dc and apply it to the output pin of IC? Gonna need some more info on how Id do this please.
                Re: Sanyo DP46840
                @selldoor, I mean the location in the service manual, prints are so small.
                @kevin, on the link, the guy cut the 12v traces that feed the amplifier, I do not think you will want to do that unless you are confident in doing it. I will have to locate that circuits section in the manual first, my eyes are real bad right now.
                For the 3.3V power supply problem, you will have to remove some parts from that 3.3V power supply to be able to inject the external 3.3V into it.
                • kevinm34232
                  • May 2012
                  • 1884
                  Re: Sanyo DP46840
                  I feel confident in doing it Im just wondering if the audio IC problem is causing the low voltage on IC1630 or vice versa. Like I said when I test voltage on the audio IC it makes the TV shut down faster like it's adding more of a load or something, I dunno it's just a guess. Is it possible that one circuit is affecting the other?
                  • selldoor
                    Slow Learner
                    • 7870
                    #49
                    Re: Sanyo DP46840
                    Kevinm, please can you post a link to the Service manual
                    • kevinm34232
                      • May 2012
                      • 1884
                      Re: Sanyo DP46840
                      I tried to post it it yesterday, it kept failing, I can email you like I did Budm.
                      • selldoor
                        Slow Learner
                        • 7870
                        #51
                        Re: Sanyo DP46840
                        Yes please - I didnt mean upload it using attachments it will be too big for that
                        I just meant put the link in a post like
                        • kevinm34232
                          • May 2012
                          • 1884
                          Re: Sanyo DP46840
                          I don't have a link someone emailed it to me
                          • selldoor
                            Slow Learner
                            • 7870
                            #53
                            Re: Sanyo DP46840
                            Ok Got SM Thanks - will see if I can split it up
                            Here are some BIG excerpts for budm.
                            • selldoor
                              Slow Learner
                              • 7870
                              #54
                              Re: Sanyo DP46840
                              SM Split into 3 zipped sections - all need to be downloaded before it will work.
                              • mikeknes
                                • Feb 2011
                                #55
                                Re: Sanyo DP46840
                                Originally posted by simplytrini
                                Hi all, hope all is well. I am wondering if anyone here has had success in fixing this model Sanyo. I am having an issue where the the green led turns on but i cannot get the high voltage for the backlights working, the screen is black and I can turn the tv on/off with the remote and power switch but that is about it. the power supply has: 5v, 15v, 12v & 3.3v. however the HV circuit for the backlight is dead. also I know the inverter board works tried it on another set ant it worked. Any thoughts would be great. Thanks
                                I have had 3 of these in shop in last 4 months .all with same problem .turned out to be main board in all three
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #56
                                  Re: Sanyo DP46840
                                  And...??? What was the fault???
                                  We tend to try for component level repairs on here - board replacement
                                  when we have given up.
                                  Please can you update your profile with country and mains voltage
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Re: Sanyo DP46840
                                    I want to give you guys an update here, I've been talking with the guy who did the audio regulator mod on IC1670. He had me cut 2 traces on the actual audio amp IC0001 to isolate it from the regulator and then check voltage on the regulator. The result was voltage was the same, still dropped to <3v instead of 13v, however TV did not shut down. I actually hooked it up and got a picture for the first time. BUT, randomly it will stil shutdown when turning on, it goes further now and backlight comes on, but sometimes will still kick off before video shows. Also, whenever I have my meter on IC1670 to check voltage it shuts TV down, so thinking this is the problem and it's hovering on the cliff now that the amp is disco'd. Obviously I have no audio at this point. So I will try the linear regulator mod and see what happens. Not sure Ill be able to repair those cut traces but oh well, I have surround sound if not
                                      Re: Sanyo DP46840
                                      Cut traces are easy enough to repair. Just strip off the copper plating on each end of the trace and run solder or a small wire across it.
                                        Re: Sanyo DP46840
                                        I believe the protection circuits also look at 13v to see it is OK or not, I believe it on page 5.
                                        At least you are getting some where now.
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          Re: Sanyo DP46840
                                          Yes it does say that it needs 13V for that IC, not sure why TV stays on with 3v, although it gets the 13v for a split second. Lenny's theory is the regulator may not even be able to power the power fail feedback signal..?? Yes getting somewhere I appreciate everyone's help.
                                          • cj_reha
                                            Mystery 80s Sanyo cap - perhaps polymer?
                                            by cj_reha
                                            Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                                            01-06-2023, 09:24 AM
                                          • Srdjan01
                                            IPhone 12 ProMax - Thoughts of (not so young) apprentice
                                            by Srdjan01
                                            Hi guys.
                                            I'm working on my first board reballing.
                                            It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
                                            Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
                                            I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
                                            03-17-2025, 02:49 AM
                                          • toddw65
                                            Sanyo DP5834 - Gray Screen
                                            by toddw65
                                            Hey All,
                                            I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                                            Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                                            Thanks,...
                                            10-31-2024, 10:37 AM
                                          • zomi
                                            Manual cof bonding success rate ?/ feedback wanted
                                            by zomi
                                            Just wanted to get some feedback,
                                            whats peoples' success rate with cof bonding repairs.....
                                            09-23-2024, 12:45 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
