LG 32LX1D half screen bad picture
  • mcross
    • Sep 2011
    • 201
    Ok guys what its doing is the right half of screen is green lines, also last time powered on was not showing the video , but had sound, then it would flicker the video, warmed the main board with heat gun on caps (the 4 470 16v smts at the top left on the main board) flicking stoped video stayed but still half video all washed out?
    power lines all look good.
    Mike
    Re: LG 32LX1D half screen bad picture
    I have seen this problem before, the one I fixed was due to loose/dirty connection on the LVDS cable, this cable is attached to the T-CON board on the LCD panel assembly.
    I see the end of this cable attached to the main board top center, but to get to the other end will require a lot of disassembly! You may as well reseat the cable between the t-con and the LCD panel at the same time.
    • selldoor
      Slow Learner
      • 7870
      From what you have tried it would suggest cap replacement would help. However the
      picture of the board is too blurred when enlarged. Can you do a picture of each board
      clear enough for us to see the component descriptions.
      In heating the caps you may have also heated other components which have affected the output voltages. What make /series are the caps.
      Please can you update your profile with the country.
      • mcross
        • Sep 2011
        • 201
        Tried the cable to the t-con , removed cleaned reset, no change, as for caps did find 2 22uf 16v smt caps bad on the main board, will replace them tomorrow and look for more, will try for better pics too
        Mike
        PS did update my info
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • iZakre
          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
          by iZakre
          Hello everybody!
          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
          The thing is that I had installed TeamViewer and could log into the computer...
          02-19-2023, 02:27 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • valvashon
          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
          by valvashon
          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
          11-24-2024, 12:08 PM
