Olevia 537-b11
    Olevia 537-b11
    Everything works ok EXCEPT--When choosing Tuner 1 as input I get "no input".
    Same digital cable works with another tv.
    Re: Olevia 537-b11
    Did it work at some time then stopped
    is digital cable cable tv or a digital tv aerial lead.
    Is Tuner 1 for digital TV
    Have you read the owners handbook
      Re: Olevia 537-b11
      Thanks---it did work 1 week ago then the tv was moved to a new location---Digital cable cacle tv---Tuner 1 is for direct cable input---yes I've read the manual
        Re: Olevia 537-b11
        I do not know this set or anything about cable so hopefully somone else does.
        When you say everything works do you mean dvd input, composite input.
        Does your cable box have hdmi socket - can you try that (if this set has hdmi in).
        Here are another couple of things to try
        1.Power on the television and press the "Menu" button on the Olevia TV's remote control.
        2 Choose the "Programming" option to view all of the Olevia setup options.
        3 Choose the "Channel Program" option, then select either "Antenna" or "Cable" (select "Cable" when using a satellite receiver).
        4 Select "Start" and the Oleiva TV scans over all the stations it receives.
        Cant find channels on tuner
        Menu>Picture>Mode>Power up>Home Then go back and autosearch channels
