Olevia 537-b11
  • marvin1234
    • Apr 2012
    • usa
    Olevia 537-b11
    Everything works ok EXCEPT--When choosing Tuner 1 as input I get "no input".
    Same digital cable works with another tv.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Olevia 537-b11
    Did it work at some time then stopped
    is digital cable cable tv or a digital tv aerial lead.
    Is Tuner 1 for digital TV
    Have you read the owners handbook
    • marvin1234
      • Apr 2012
      • usa
      Re: Olevia 537-b11
      Thanks---it did work 1 week ago then the tv was moved to a new location---Digital cable cacle tv---Tuner 1 is for direct cable input---yes I've read the manual
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Re: Olevia 537-b11
        I do not know this set or anything about cable so hopefully somone else does.
        When you say everything works do you mean dvd input, composite input.
        Does your cable box have hdmi socket - can you try that (if this set has hdmi in).
        Here are another couple of things to try
        1.Power on the television and press the "Menu" button on the Olevia TV's remote control.
        2 Choose the "Programming" option to view all of the Olevia setup options.
        3 Choose the "Channel Program" option, then select either "Antenna" or "Cable" (select "Cable" when using a satellite receiver).
        4 Select "Start" and the Oleiva TV scans over all the stations it receives.
        Cant find channels on tuner
        Menu>Picture>Mode>Power up>Home Then go back and autosearch channels
        • CapLeaker
          Dell ATX PSU won’t start, but forcing it works fine?
          by CapLeaker
          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
          10-28-2024, 06:59 PM
        • DXseekerMO
          Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
          by DXseekerMO
          I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
          As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
          09-15-2021, 05:15 PM
        • goodpsusearch
          Sony STR-DE445 did I get a faulty IC?
          by goodpsusearch
          Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
          First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
          So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
          I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
          Also fixed A LOT of cold solder joints and also done some modifications,...
          04-15-2023, 04:16 PM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ex250
          Kenwood SW-505D no sound issue and pops from time to time when it works
          by ex250
          Hello mates,
          I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
          It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
          12-29-2024, 03:27 PM
