This will help explain what you see on the screen.
Learn about LCD panel and T-CON board
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Learn about LCD panel and T-CON board
Budm, good information.
Tried to find a replacement IC for the defective audio output of the Sharp I have been working--seems forever. The no sound issue is due to two IC's, a TA2024 and a AK4586VQ. The latter IC provides one L/R output for the monitor output which works fine and another L/R output for the power amplifier, to drive the speakers which doesn't work. The TA2025 power amp is also bad, voltages are too far off and when the monitor oitput is bridged to the input of the TA2024, there is no out.
Can you advise if you know where I could find these parts. Neither Mouser or Digikey list either IC. Otherwise, will just install a generic audio stage and drive it from the monitor outputs and reconnect the internal speakers to this amp. former IC.
Thanks -
http://www.ebay.com/itm/110851974901
http://www.findchips.com/avail?part=TA2024
shows Quest has them in stock.--- begin sig file ---
--- end sig file ---Comment
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
Hi All,
Need help.
I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard.... - Loading...
