Vizio SV320vxt popping fuses like it made it up.
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Vizio SV320vxt popping fuses like it made it up.
    also beacause you have a backlight,it means your inverters are working,unless the white screen dissapears after a few seconds
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      sorry did you mean the screen turns white,or the power light?
        Do you mean the VZIO LOGO stays white instead of Amber? Or the TV screen just has white glow? Can you see the backlights are on?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Hi- Now you have got it back on, I think you should test the voltage across the BIG cap as there seemed to be some doubt earlier that it was operating correctly.
          Meter on 600V DC and observe the polarity - HIGH voltage so great care. Once the high voltage is established as ok move on to testing the outputs.
          - you might want to read this
          https://www.badcaps.net/forum/showth...t=19245&page=2
          Post 40 has budm's load and voltage tester which you might want to try to see if your output voltages are sound.
          • shwsrvcs
            • Jan 2012
            • 69
            my bad, the screen isn't white.. it's just the amber light that turns white, the screen stays dark and moreover, its not getting a signal sent to it that I can see (as in not just the backlights aren't powering up, the main board isn't going up either) on those second set of mosfets on the primary side (q601 I believe) one was also not matching up. could it be that one should be replaced?
            so far I've replaced, the rectifier and that first mosfet
            that q601 on the board was reading as follows in comparison to the others which I take for "normal"
            Q802 }{ 2.590 }{ 0.5 }{ 0.5 }
            Q601 }{ 4.45 }{ 0.7 }{ 4.45 }
            Q603 }{ 2.421 }{ 4.41 }{ 0.5 }
            dg
            • shwsrvcs
              • Jan 2012
              • 69
              #26
              and sorry for the hold up on the reply.. I stayed up all night working on this and a toshiba laptop.... and a website.. and when I wrote about the power light coming back on, it was on my last patch of "awake" time left. I am just now getting back on the job and am heading out to pick up a 16" lcd panel for the laptop and a few fuses for this job. (currently running with one I borrowed from the E321VL I have up next to work on.
              • shwsrvcs
                • Jan 2012
                • 69
                #27
                I am crafting one today, need a couple of things from hardware store. going there now
                dg
                • shwsrvcs
                  • Jan 2012
                  • 69
                  #28
                  errr. didn't get that light fixture quite done, but I am gonna try again in the morning.. I did however find the voltages from the multimeter.. and they are with both the power button pressed and also in standby..
                  .3 for PSON
                  3.2 for 12v
                  5 v for svsb
                  and still no fuses blown since ever.. oh.. I pulled the main caps and checked em with the meter, they both dropped and then chlled at low reading. I decided to try and replace em just in case, but nope... no 68uf 470V at frys. will try marvac in the morning..
                  • shwsrvcs
                    • Jan 2012
                    • 69
                    #29
                    oh.. fuses on the main board 2 by the power connection both read at .1 and beep on continuity setting
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #30
                      Did you do this before you removed it?
                      • multimeter
                        • Jan 2011
                        • 739
                        • united kingdom
                        #31
                        .3 for PSON
                        3.2 for 12v
                        5 v for svsb
                        .3 for the ps-on dosent look good...or 3.2 for the 12v...,that with power on?,and standy button pressed for on?
                        • shwsrvcs
                          • Jan 2012
                          • 69
                          #32
                          no I had not because actually after re-reading the posts inline, I realized that your mention that there was mention about it being bad earlier was in fact the first mention of the possibility of the big cap operating incorrectly in the post. Kinda like foreshadowing but in a less foreshadowy way. But it did plant the idea that it could be bad
                          Moreover, this board's big cap is 2 smaller caps acting as the big cap side by side. I was heading out to fry's to get a couple things and thought it may be nice to get those 2 "just in case" but guess I thought a thought too soon as the specs for them were glued on the board face down by the glue they put in for assembly time
                          I cut them loose and then read the bottoms 68uf 470dv... which frys's does not carry, not sure about good ole tandy co. they closed before I got there.. I'm going to Marvac as soon as it opens to try and get em.
                          But with that in mind, for the set of reading in my last post were done by me indoors with controlled conditions and yest with the power/hold button pressed (vizio white light in front on) and off (amber vizio light lit.)
                          and so to test the caps, as there are two on this board. what can I do to ensure a proper and accurate reading?
                          DG
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            If you have them off the board not a lot (unless you had an ESR meter)
                            You can test for shorts and that's about all.
                            • shwsrvcs
                              • Jan 2012
                              • 69
                              #34
                              i'd only taken them off the board to get the right numbers (which were printed right where they were glued to the board. when they were on the board, they were looking okay though and they ohms seemed to be working okay, but i never checked for the voltage and after i got the numbers I put them back on the board since they weren't bad.
                              SO they are on the board, I can measure them, and I will... I was hoping for a little procedural assistance to measure, as in series, individualy, etc... and in the case if these results come up that they are both within spec, what is the next item? to review.. the models has:
                              1 would not power - blowing fuses... fixed, no more fuses have blown
                              2 vizio symbol lights amber and turns to white, but no picture or audio -
                              this was where the suggestion for the big cap testing was made as it was confused that the white light meant the lcd panel.
                              This was where I went off to try and build that light bulb piece and then thought, well , I may as well buy the caps in case they are bad just in case.. came back without the switch for the lights and without the caps since they didn't have the right one.
                              with nieither in hand, i checked the voltage as suggested in the other messages in line and viola, now here I am. About to test the voltage on the caps.
                              back in a few with the results.
                              • shwsrvcs
                                • Jan 2012
                                • 69
                                #35
                                okay, the first big cap 160 dc
                                The second big cap 0 dc
                                • shwsrvcs
                                  • Jan 2012
                                  • 69
                                  #36
                                  okay.. no 68uf 470v caps here, in all of the different component electronics, a the LCD tv's here, all the power boards --- i dunno.. maybe just 10 or 15 total, but seiously.. in all of those, I could not find a single instance of capacitors being of the same ratings.. not a single one. I don't understand that. perhaps ill ponder that tonight for a while. right now i'm heading to MarVac, with any luck they well have that size.
                                  do any others work if they are done in series or in parallel? and if so. is it the voltage to worry about or the microfarad rating or both and if both how do they interact when wiring up in series or in parallel? I think I need to get some schooling going on here.. this is too many questions for a board, and youtube aint helping me with 10 year old trying to show me how to solder by plugging the damn iron into the wall...
                                  DG
                                  • cashkennedy
                                    • Aug 2011
                                    • 666
                                    Im pretty sure for the huge dc cap you can replace it with any voltage from 470v - 600v.
                                    I think i read somewhere also that the capacitance wasnt very important so long as it was rather low.
                                    So if you see something in the range of 470v-600v, with 65-70uF capacitance, then you should just use that. You might have to modify the way its attached / mount it sideways to get it to fit.
                                    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Thats odd that the caps are 470 volt, but if you know the voltage that they will run at, you might be able to use 450 volt ones which are more common. I cant think of any caps that go above 450v
                                      -Ben
                                      Muh-soggy-knee
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Um, please read those again, they are in parallel, so they should both read the same!
                                        -Ben
                                        Muh-soggy-knee
                                        • cashkennedy
                                          • Aug 2011
                                          • 666
                                          ((The DC power on the primary side is relative to how much it is amplified before the bridge rectifier and whether its US 110v, or europe 220v. Modern designs that can handle european input are usually made with 600v caps i believe.)) nevermind im probably wrong on this, the common voltages for these caps must be slightly lower, perhaps the 450v is the common one for europeans 220v capable designs.
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Sik_6ty_Sixx
                                            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                            by Sik_6ty_Sixx
                                            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                            02-18-2025, 05:06 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
